Drain the fuel from C5
Old Oct 30, 2011 | 11:37 AM
bheston's Avatar
bheston
Default Drain the fuel from C5
So after the kiddies arrived, the vert has been sitting in the garage. The fuel is getting a little old. Although I treated with Stabil, it's still 2 years old.
What is the easiest way to get the fuel out other than driving?
- Pull hose off the intake and let the fuel pump push out the fuel when trying to prime?
- Stick a hose in the fill port and suck it out?
Old Oct 30, 2011 | 11:59 AM
lucky131969's Avatar
lucky131969
How much fuel is in the tank?
Old Oct 30, 2011 | 12:03 PM
hotwheels57's Avatar
hotwheels57
If you put STA-BIL into the tank, it should be fine. It might be a little degraded in octane level, but the computer should be able to adjust for that. If you can, top off the tank with premium and drive it (easy). Do that a few times to insure the fuel quality.
Draining fuel from a C5 isn't as easy as the cars of the ol' days.
Old Oct 30, 2011 | 12:20 PM
bheston's Avatar
bheston
The fuel is 2 years old. Still starts right up, but will be stored again all winter. There is about 1/2 tank full. I thought I could pull the fuel out and run in my work car while it still burns (versus weed killer later).
Maybe I can suck out 5 gallons and replace with a fresh 5 gallons?
Old Oct 30, 2011 | 12:25 PM
lucky131969
The thought of going to that much trouble, so you can capture the gas for the other use, is beyond me. As suggested, top of the tank with fresh fuel (add stabil), and call it a day. You'll be fine.
Old Nov 28, 2011 | 01:28 PM
Greg Gore's Avatar
Greg Gore
That's not the answer he was looking for though. He might not feel good about burning old gas in the C5 or running old gas through his injectors. You can't just dump it out so why not feed it to a work car or fishing car?
Old Nov 28, 2011 | 01:46 PM
jrose7004's Avatar
jrose7004
Go and top off the tank, add Sta-Bil and call it good.
Old Nov 28, 2011 | 02:00 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Fishing car? I gotta get me one of those!!
OP, if you insist on draining your tank, you can remove the relay and short the contact positions. Standing at the passenger fender looking toward the motor, the relay box is just to the right of the battery and the relays are labeled under the cover. Remove the relay and short the top left and bottom right pin positions.
Remove the schrader valve at the end of fuel rail and screw a -4 line at the end and extend it to a fuel can. You can also use a fuel line disconnect tool and slide a hose over the main feed line between the brake booster and engine.
Once you have the hose secured, turn the key on and the fuel pump will run wide open.
Old Nov 28, 2011 | 04:56 PM
pjensen's Avatar
pjensen
What fuel hose would you use (that would stay on)? The fuel pump is 62 psi and might spray everywhere after it knocked a hose off.
Is there a 4' fuel hose that screw on the fuel rail and depress the schrader valve?
Or am I just over thinking this?
Old Nov 28, 2011 | 06:33 PM
Z06supercharged's Avatar
Z06supercharged
If you dont wanna do the relay way.... You can just key on, key off to drain it and it will spit some out each time. I did it that way once and took maybe 5 mins to get 3 gallons out cause the fuel pump does not stay on unless car is running and only pumps for about 4 seconds each time, but it pumps quite a bit each time. I couldnt get the damn relay way to work for whatever reason so I said F it and did it the ol fashioned way...I just slid a tight fitting hose over the threads and it stayed on just fine. Here are instructions for relay way Bret described above from A&A website with some pictures: http://www.aacorvette.com/pdf/aa_fue...structions.pdf
Old Nov 28, 2011 | 07:23 PM
vettenuts's Avatar
vettenuts
Personally, I would take it out for a few hours and run it. That would to two things, burn the fuel and lubricate the internals of the motor real well. Then re-fill and put it away. I am not a big fan of emptying the tank with the fuel pump. Too risky IMO when there are much simpler alternatives.
Old Nov 28, 2011 | 08:20 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Go drive it and burn off the old fuel down as far as you dare. Add Stabil and fill it all the way up then drive it for ten miles or so. This will get treated gas through out the fuel system. Space in the tank is your worst enemy for moisture forming and moisture is way worse than anything old fuel would cause. Stabil works for 18-24 months. I use it all the time in small engines that are WAY more sensitive than an LS series V8.
I am in landscaping and I lay up several engines for the winter! Never had and engine not restart in the spring because of a fuel problem!
My $00.02
Old Nov 30, 2011 | 12:09 AM
toddk's Avatar
toddk
So after the kiddies arrived ...
By the way, Congratulations! Sounds like time for a couple trips! With plural kids, the first time in the Vette is fun to watch their reactions, and they all need a turn. Should've thought about this earlier when top-down would have been an option. Hopefully you have an '00.5+ with the airbag disable switch, or an '03+ with the LATCH hooks on the passenger seat frame. Might want to update your profile.
However you decide to burn it out, you may want to run some Seafoam in the next full tank to dissolve any varnishes that may have begun to form.
As a side note, I don't know if I could go two years without a drive in my Vette. You must be a man of considerable self control, or your wife had hidden the keys.
Todd
To Drain the fuel from C5
