Coupler noise?
Nov 2, 2011 | 12:19 AM
Coupler noise?
I have an intermittent popping noise that I cannot identify. I thought it was binding sway bar bushings but I've lubed, Tefloned and adjusted them and the popping remains.
Could this be noise from failing torque tube couplers?
My 99 has about 66k miles with a 415HP LS1 that I bought with about 60k miles. I don't know if it was abused by the previous owner or not. The rest of the car seems well cared for.
Your thoughts appreciated.
Nov 2, 2011 | 12:21 AM
Quote:
Originally Posted by
flynhi
Where is it coming from? Any codes?
Nov 2, 2011 | 12:50 AM
The poppng noise is sometimes fore and sometimes aft. That's why I thought it was sway bar bushings.
No codes.
Nov 2, 2011 | 06:06 PM
Did you go over the suspension to see if anything is loose? A slightly loose sway bar end link can pop and bang badly.
Peter
Nov 2, 2011 | 07:39 PM
lionelhutz
Peter
Yes, I have checked and tightened all around.
Nov 2, 2011 | 10:09 PM
I'd guess shock first but it could be a ball joint or a bushing I suppose.
A torque tube bushing is more likely to cause vibrations than popping sounds.
Peter
Nov 2, 2011 | 10:25 PM
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Keep looking at end links. I replaced mine with metal,,,not even a squeak since.
My $00.02
Nov 2, 2011 | 11:01 PM
lionelhutz
Peter
Thanks fellas.
I'm now thinking the rear spindle needs to be lubed as described in
http://forums.corvetteforum.com/c5-t...earings-2.html
Nov 2, 2011 | 11:57 PM
When does the noise happen - going from forward to reverse or when driving down the road?
Peter
Nov 3, 2011 | 01:19 AM
lionelhutz
Peter
Generally early in the AM when leaving the garage and neighborhood. It seems to happen less often after driving a few miles.
