C5 TECH do you recommend using fuel injector cleaner, ever???
Old May 6, 2002 | 01:23 AM
AVETTE's Avatar
AVETTE
Cruise-In II Veteran
Cruise-In III Veteran
Default C5 TECH do you recommend using fuel injector cleaner, ever???
I know that everyone says don't use snake oil like slick 50 in your engine, fine. What about fuel injector cleaner that you pour into your gas tank? Does that stuff work? Any possible bad side effects? Do fuel injectors become clogged over time, like you see in the commercials, and the 'fuel injector cleaner' really opens them up, thanks.
Old May 6, 2002 | 10:52 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: C5 TECH do you recommend using fuel injector cleaner, ever??? (AVETTE)
I have been using the Redline complete fuel system cleaner 1 bottle every 5-6 tanks and so far no problems :D
Old May 6, 2002 | 11:34 AM
Son93SL2's Avatar
Son93SL2
I use Cheveron Techron Concentrate from the Cheveron gas stations, works great. :)
Old May 6, 2002 | 12:05 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: C5 TECH do you recommend using fuel injector cleaner, ever??? (Son93SL2)
I just have the dealership do a complete fuel system flush every 20k miles.
Old May 6, 2002 | 12:08 PM
robsvette's Avatar
robsvette
every oil change i do it
Old May 6, 2002 | 12:18 PM
2kbluestreak's Avatar
2kbluestreak
I've been using good, name brand gasolines that say "detergent" for the last 12 years in all my family's cars and have not been using bottled cleaners. So far, lots of miles and no problems. :yesnod:
Old May 6, 2002 | 01:38 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
I would just save my money and then replace my fuel injectors at every 50K to 75K miles. :D The cost is probably end up to be the same, but you are getting a brand new set of injectors.
:cheers:
-Tuan
Old May 6, 2002 | 01:41 PM
Tormania's Avatar
Tormania
Cruise-In IV Veteran
Cruise-In V Veteran
I had a flaky idle problem on my 2000 C5 and took it into the dealershipt to have it fixed. They adjusted the PCM calibration for the idle BUT the tech also recommended having the fuel injectors cleaned. My car is just shy of 33K miles and I asked why should they be cleaned now, shouldn't they be good for 100K miles?? He said they can get gummed up anyway and cleaning them out usually fixes the type of idle problems that I was having. I didn't want to pay for the service (89.95 is a rip IMHO) but if it fixes the idle then so be it. Part of the service included putting a bottle of 44K in the tank so they use those kinds of additives in their normal injector cleaner service so it can't be all that bad. My idle is now all good so I guess I will swallow the cost and be happy that my car doesn't try to die every down and then. :cheers:
Old May 6, 2002 | 02:30 PM
zcobra1's Avatar
zcobra1
Chevron "techtron" BEFORE each oil change does the trick for me. I heard it is best to do it right before your oil change, so if any fuel w/ the "Techtron" washes into your oil, it is rinsed out w/ the change.
Old May 6, 2002 | 03:03 PM
B. Stewart's Avatar
B. Stewart
Chevron with Techron or just the Techron in a bottle. :D
Old May 6, 2002 | 08:29 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: C5 TECH do you recommend using fuel injector cleaner, ever??? (B. Stewart)
Techs at two different dealerships in my area recommended the GM Fuel Treatment for occasional use, they said it is the same as the Chevron stuff.
Old May 6, 2002 | 11:35 PM
mozin's Avatar
mozin
I use the Slick 50 gasoline additive some of the time and the Techron other times. My thought is the same as with changing to different gasoline brands, to get a wider variety of additives to clean all the gunk out of the engine.
Old May 6, 2002 | 11:38 PM
davidmax's Avatar
davidmax
Default Re: C5 TECH do you recommend using fuel injector cleaner, ever??? (Gearhead Jim)
Techron every 3-4K right before the oil is dumpped.Dave S.
Old May 7, 2002 | 10:46 AM
ronnie948's Avatar
ronnie948
Default Re: C5 TECH do you recommend using fuel injector cleaner, ever??? (davidmax)
STP complete fuel system cleaner every 10,000 miles or so.Just pour it in the gas tank before A long trip and let it do its thing.I used it on my 3000GT and never had A problem so I now use it in my 98 vette. I have 40,000 miles with no problems. :cheers: :chevy
Old May 7, 2002 | 09:57 PM
akw408's Avatar
akw408
Just wondering, if your fuel filter is working, why would the fuel injectors get clogged up?
Old May 7, 2002 | 10:48 PM
VetteDawg's Avatar
VetteDawg
I KNOW that I read a thread on this forum a while back where everybody said NOT to use ANY of that stuff.
My 2000's only got 7500 miles on it but pretty soon I'm going to buy one of those kits (like from Eckler's) and do a cleaning...myself.
Old May 8, 2002 | 12:31 PM
c5 Lee's Avatar
c5 Lee
Default Re: C5 TECH do you recommend using fuel injector cleaner, ever??? (akw408)
IMO the fuel filter is supposed to remove any particulate matter that could get into your fuel system. Obviously gasoline or most liquids will pass through.
Gasoline has several different chemicals and solvents in its composition ( I actually believe it is over 100). Some of these chemicals, under varying conditions, create a gummy varnish like residue. This is what clogs our stuff up.
Not all of the components in Gasoline are meant to be combustible some are for lubrication, detergency, emissions etc.......
Like I said IMO.
Lee
To C5 TECH do you recommend using fuel injector cleaner, ever???
Old May 16, 2002 | 11:22 PM
Bandit1's Avatar
Bandit1
44K at every oil change. :yesnod:
Old May 16, 2002 | 11:54 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: C5 TECH do you recommend using fuel injector cleaner, ever??? (2kbluestreak)
A friend of mine has an oil distributorship and he says that all fuel comes through the pipeline the same.
It's where they fill the tankers, that move fuel to gas stations, where they add the stuff that makes is 93, 91 octane or what ever brand specific stuff the oil companies want to add that makes their gas better than the next guy's.
fuel injector cleaner, or detergent is added to all major gasoline brands. The guy that runs dirt cheap gas doesn't have it, that's why it's cheaper.
Believe me if I thought for a second that my injectors were in the least bit restricted I would be all over the fuel additives...but they are in every tank I burn.
I'll save that expense and use it towards more brake pads & rotors!
Old May 17, 2002 | 12:21 AM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
44K is the way to go. It is one of the three steps used by service centers to clean the fuel injection system. This stuff works great. But, some shops may not sell it to you over the counter. It is usually about $20 a can. If you get some, be extemely careful adding this to your fuel tank. If you even get a little on your paint, you will :cry .
