Reduced Power Engine and some codes.. plz HELP
Old Nov 8, 2011 | 09:15 AM
sagrea's Avatar
sagrea
Originally Posted by dougbfresh
What codes do you get NOW-the EBCM was an issue and will cause the reduced Power issue.
I got new code now after I disconnect the battery again..
The code is P1275 H appearantly it was history code,,
I cleared it but the problem is still there REDUCED POWER ENGINE
the above code is so related to my symptom, I think it is related to athe ccelerator sensor,,,
I guess I need to fix or replace it,,
Old Nov 8, 2011 | 09:18 AM
sagrea's Avatar
sagrea
Originally Posted by cdkcorvette7
Now pull your codes again and post ALL of them. Start your car and pull the codes before turning off the ignition...
I got new code now after I disconnected the battery again..
the above code is so related to my symptom, I think it is related to accelerator sensor,,,
Old Nov 8, 2011 | 09:22 AM
dougbfresh's Avatar
dougbfresh
Is that the ONLY code you get?
Here's a pic of the unit:
http://chevythunder.com/drive_by_wire.htm#1998-2005 Corvette/ Truck APPS (accelerator pedal)
There's a link to the C5 unit at the bottom-you may just have a poor connection at the pedal.
Old Nov 8, 2011 | 11:56 AM
lucky131969's Avatar
lucky131969
Please see procedures below:
Old Nov 8, 2011 | 11:57 AM
lucky131969
continued from previous post (page 7 of 7)
Old Nov 8, 2011 | 11:59 AM
lucky131969
P0327:
Old Nov 8, 2011 | 12:03 PM
lucky131969
P0748:
Old Nov 8, 2011 | 12:05 PM
lucky131969
Given the nature of all these things happening at once, I think there is value in inspecting the PCM connectors for corrosion (prior battery lead), and security. It may lead to nothing, but it's worth inspecting.
