Projector Head Lights
Old Nov 4, 2011 | 08:34 PM
c5Cruiser's Avatar
c5Cruiser
From: Corona CA - "An Armed Society is a Polite Scociety"
Default Projector Head Lights
Has anyone installed Projector Head Lights on there C5?
Any pros and cons?
I broke my head light lid while trying to adjust it and the replacement cost is more than half of just replacing the both with projector lamps.
http://www.ebay.com/itm/140559739410...S:1123&vxp=mtr
Thanks for any input.
Old Nov 4, 2011 | 10:57 PM
c5Cruiser's Avatar
c5Cruiser
After posting I have read lots of posts regarding replacement lights.
I'd still like to know if anyone ever bought these and how they turned out.
Thanks for your input.
Old Nov 5, 2011 | 12:00 AM
Dale002's Avatar
Dale002
I've had them and they are cheap for a reason. They are crap! The lens started showing stress crack within a month,They don't fit very well and there is no adjustment for fitting them to the body. Plus they just look cheap when installed. I would replace your lids. I've seen them on the forum for as low as $100 each. If your light are functional for the exception of the lid.Go with the OEM. There are some better projection fix lights for the C5,but they are much more,around $1000 to $1500 for a set. Look at my picture,I think i still have my old 98 on there with the lights installed.However,If you do go ahead and installed the projection lights,I would be interested in purchasing you OEM ones.
Old Nov 5, 2011 | 02:32 AM
FourG63 97GST's Avatar
FourG63 97GST
Pros, great with HIDs installed since oem light output is horrible.
Cons, fitment and it's not visually appealing imo
I'll look for a lid first, how bad is the damage?
Old Nov 5, 2011 | 06:41 AM
CJW's Avatar
CJW
Default projector lights
Hi I bought a set of direct replacement headlamps from ebay (D5_ concept) they have a projector light built in, replaced the cheap bulb they came with (Piaa cost £75), they are really good and keep the O/E look, also came with wiring harness so on high beam all four lights come on
Old Nov 7, 2011 | 01:20 PM
c5Cruiser's Avatar
c5Cruiser
I re-attached the rear broken part (the one with 2 crews) with JB Weld yesterday. The one side is toast so I have the rear and other side to hold on to it. The other side I'm going to secure it with the same screw but using a larger washer to help secure it. I thought I would give the JB 24hrs to cure before re-installing them.
Keeping my fingers crossed.
I'll post after I finish and let you know how it went.
Old Nov 7, 2011 | 01:57 PM
Dale002's Avatar
Dale002
3M sells a product just for this purpose. Go www.3M.com and search tabs repairs. They have a video on how to do it.
Old Nov 7, 2011 | 04:10 PM
Tech's Avatar
Tech
Thought I replied to this.. do you have 2 threads? I used Duramix 40/40 to repair mine ~2 years ago. It's a 3M product.
Old Nov 7, 2011 | 04:32 PM
CJW's Avatar
CJW
I'll take a look. Thanks!
I can't see paying a grand or more on lights right now let alone having to get the okay from the misses.
I checked them out and they look very much like these.
http://www.ebay.com/itm/97-04-CORVET...sories&vxp=mtr
Which frankly where my forst choice.
I understand that adusting the beam is rather difficult if not impossable tho.
These lights fit and adjust like OEM though I thjnk if you fit HIDS you might have to modify the housing (cut away a small amount ) to accomodate the bigger bulb
Old Nov 7, 2011 | 05:01 PM
c5Cruiser's Avatar
c5Cruiser
You may have.
I have a thread regarding the headlight lid, a thread regarding input on replacing my headlights with projectors and discarding the lids altogether and one on input on a tow package.
Sorry for any confusion.
Old Nov 7, 2011 | 07:49 PM
luc719's Avatar
luc719
what directions did you use to install these? i just bought them.
Old Nov 9, 2011 | 01:00 PM
CJW's Avatar
CJW
http://forums.corvetteforum.com/c5-g...iggle-fix.html
Jnstructions for fitting headlights
Old Nov 9, 2011 | 01:04 PM
CJW's Avatar
CJW
http://forums.corvetteforum.com/c5-g...otsa-pics.html
Old Nov 22, 2011 | 09:02 AM
luc719's Avatar
luc719
Hi thank you for responding back to me about the hid bulbs, i am going to be doing that to but i ment to ask you what directions you used to install the d5 concepts projector lights because they dont give directions. thanks
Old Nov 22, 2011 | 09:04 AM
luc719's Avatar
luc719
sorry i just seen the second link! lol thanks again.
Old Dec 2, 2011 | 09:34 AM
luc719's Avatar
luc719
sorry to bother you again but did yours come with hid ballast's?
Old Dec 2, 2011 | 12:40 PM
CJW's Avatar
CJW
Hi No they didn't with ballasts I bought the lights without the HID option but at the time you could buy with HIDS think you still can but i've just bought some hids and should be fitting them shortly
To Projector Head Lights
