Crank Reluctor Clearance Help
Old Nov 4, 2011 | 08:55 PM
o1Z0sick's Avatar
o1Z0sick
Default Crank Reluctor Clearance Help
This has been bothering me for a few days so I took a few pics in hope of some guidance. What is the accepted clearance between the #5 main cap and the crank reluctor wheel? I have a hair over 0.011" clearance as checked with a 0.011" feeler gauge. I checked run-out and it is 0.020" (within the 0.028" max spec). The block is a new LS3 and the crank is a K1 with a 24x wheel. The engine was built by a reputable LSX shop in Houston.
What bothers me the most is that to install this wheel (as per precision engine) there is a 0.007" interference fit with the crank and when heated to 450*F it slides right on. Will thermal expansion of the #5 block main or cap main cause a problem? Any help would be great before running a bad wheel screws up my brand new block.
Old Nov 6, 2011 | 11:17 PM
o1Z0sick's Avatar
o1Z0sick
Anybody check this before?
Old Nov 7, 2011 | 08:52 AM
CHJ In Virginia's Avatar
CHJ In Virginia
I would get on the phone to the builder ASAP before you go any farther with the assembly.
Old Nov 8, 2011 | 01:50 PM
o1Z0sick's Avatar
o1Z0sick
It is proving very difficult to get a response from them and I am not just the only one. To me, CUSTOMER SERVICE is really what makes or breaks this hobby.
Does anyone else have their engine on the stand? Can you check this dim for me?
Old Nov 8, 2011 | 02:36 PM
cdkcorvette7's Avatar
cdkcorvette7
No idea... free bump. Good idea getting info before proceeding. You definitely need to talk to someone who's done this before...
Old Nov 8, 2011 | 03:09 PM
lucky131969's Avatar
lucky131969
I'm not sure I understand your concern here. The interference fit, is between the ID of the reluctor, and the OD of the crank. If the reluctor is heated, this facilitates installation, and then becomes secure as it cools. When the crank and reluctor are heated(at the same rate during engine operation), it will stay in place......because there is no disparity in temperature.
I would not be concerned about the CTE, as much as how you are taking the measurement. Have you incorporated your crankshaft end play measurement?
Old Nov 8, 2011 | 07:16 PM
o1Z0sick's Avatar
o1Z0sick
I am referencing the clearance or gap between the main cap and reluctor wheel. If the main and wheel both expand at temperature they move closer together making the clearance smaller.
The measurement is taken with the crank pushed back, end play is 0.004".
Maybe this is the way GM designed it to fit, but damn that's tight IMO.
Old Nov 8, 2011 | 07:41 PM
lucky131969
Ok. Speaking strickly to an LS1/6 crankshaft, that end play would be considered good. So you have a minimum clearance of .011, and a maximum clearance of .015. If you look at the sensor pickup, the window is narrow. It does not take much deflection in the reluctor to cause problems. Even in the event that the surfaces did make contact, they are well lubricated. Take not of some of the other clearances in the engine......like the crank counter weights to the block.
Old Nov 8, 2011 | 09:53 PM
o1Z0sick's Avatar
o1Z0sick
I found this image over at gm high tech. It looks really tight here too. This makes me feel a little better.
Old Nov 9, 2011 | 03:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
How does the reluctor wheel line up with the sensor?? Look thru the sensor hole and MAKE SURE that they are correctly centered in the hole.
BC
Old Dec 16, 2011 | 11:14 AM
o1Z0sick's Avatar
o1Z0sick
Pulled the crank, took it to LME, new reluctor installed with only 0.006" runout. Cap to wheel clearance is now a much more acceptable 0.025".
To Crank Reluctor Clearance Help
