How often do you replace your Clutch?
Old May 6, 2002 | 01:10 PM
TDogg72's Avatar
TDogg72
Default How often do you replace your Clutch?
How often do you replace the clutch in your Manual Transmission(duh) C5?
Note: This is not meant for people who regularly race there C5
Old May 6, 2002 | 01:13 PM
borba's Avatar
borba
Default Re: How often do you replace your Clutch? (TDogg72)
Mine is a 98 and I have not had to do anything with the tranny. I though the clutch was good for 100K if taken care and not race a lot.
Old May 6, 2002 | 01:23 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
You've just excluded 99.9% of the people here. :lol: :lol: :lol:
How often do you fill-up your car? Note: This is not meant for people who drive their C5's regularly. :lol: :lol: :lol: Just messing with ya. :D
Anyways, back to you questions....I got approximately 21K miles out of my stock clutch. But that is because I drive like a maniac.:D
:cheers:
-Tuan
Old May 6, 2002 | 01:35 PM
Mike Siska's Avatar
Mike Siska
I got 5800 miles out of my 01's clutch. Now it's got an 02 clutch in it. One of my club members made a comment that if you race, you can make the clutch one of your consumables just like oil, gas and tires.
Old May 6, 2002 | 01:53 PM
Tormania's Avatar
Tormania
Cruise-In IV Veteran
Cruise-In V Veteran
Replaced mine at 20K miles because of the lazy clutch problem. Now at 33K miles it goes in next weak for the same damn thing!! :mad :mad
Old May 6, 2002 | 06:44 PM
luvinc5's Avatar
luvinc5
Default Re: How often do you replace your Clutch? (Tormania)
Luckily, I'm still on the original clutch and yup, it's all good. Going in for a flush to the hydraulic clutch line soon.
Old May 6, 2002 | 08:36 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
My First clutch was replaced at 8,000 miles because it was warped. The Disc looked good with lots of meat on it. Replaced with a McLeod Single Disc, Pressure Plate and Aluminum Flywheel.
The second clutch was replaced at 17,000 miles. Looked good, no warping, lots of meat on the disc. Replaced with McLeod Dual Disc, New Pressure Plate, New Aluminum Flywheel, AP Adjustable Master & Z06 Slave.
vetterdstr :cheers:
Old May 6, 2002 | 11:34 PM
davidmax's Avatar
davidmax
Default Re: How often do you replace your Clutch? (borba)
If you run under 550 rrwhp a Star 3 clutch should give you lots of life.If its 550 or above the Star 4 has amazing holding and wear charectoistics.We've pulled motors run hard on stage 3's at 18K miles and they have had 70% life left most people upgrade to the Star 4 so they dont have to pay 3-400 clams when essiantually your install is 100 tops.Yours Truly David S.
Old May 8, 2002 | 10:49 AM
C6VETTE4FUN's Avatar
C6VETTE4FUN
I just broke 30k on my 97 and just started to get some slipage..
sounds like I will be changing mine soon. Any advice to stick with
stock replacement?
Old May 10, 2002 | 12:28 AM
vetterdstr's Avatar
vetterdstr
Default Re: How often do you replace your Clutch? (1997C5VTBOY)
You can get a stock clutch, or a Z06 clutch and it will work fine for your stock car. :yesnod:
vetterdstr
To How often do you replace your Clutch?
