HELP ABS code C1255
Old Nov 8, 2011 | 10:37 PM
XXXLTRP's Avatar
XXXLTRP
Default HELP ABS code C1255
28 TCS C1255
I searched and have found some information, but no answers. I know it means " EBTCM Internal malfunction" but that's all I can find.
1999 fixed roof coupe, 6 speed, 79,000 miles
I just installed new rotors and pads, a few days ago...then the code popped up today and set the ABS light off. Coincidence?
I've found the threads on repairing newer ones, but mine is located up front and older/ different than the ones being repaired.
A little help please.
Old Nov 9, 2011 | 07:07 AM
XXXLTRP's Avatar
XXXLTRP
I did not find that thread in my search, thanks. I'll have my friend pull the codes to get the sub codes and see where I stand.
Old Nov 9, 2011 | 08:49 PM
Paul Wood's Avatar
Paul Wood
There are no coincidences. I am no expert but I believe I have read where there are wheel rotation sensors that work in concert with the ABS/Traction Control system. If you have been working around them you might have hit or damaged a connector or have an exposed wire. There are many on this forum that know more about this than me. Try Lucky he seems to know the electrical system better than anyone. Good Luck.
Old Nov 9, 2011 | 11:38 PM
XXXLTRP's Avatar
XXXLTRP
My friend pulled the codes for me using his computer (the best on the market, mechanic by trade). It only showed the same code I was able to pull...no more digits than the c1255, unlike others that had two more digits that pointed to other problems ( wheel sensors and ect)than the ECBM itself.
He was able to reset it, but it came back on. It has gone off 2x by itself, only to come back on. I have cleaned the large plug, nothing out of the ordinary when I pulled it off and inspected it. I also cleaned the ground connection...
Old Nov 9, 2011 | 11:44 PM
XXXLTRP's Avatar
XXXLTRP
I also inspected the wheel sensors prior to pulling the codes..all visually looks ok. It's not the first time I have done the brakes on this car...and I didn't have any issues this time. If it displayed another 2 digits that pointed to a wheel sensor or some other piece of the ABS/ traction control system I'd blame myself for damaging it, but it's not the case.
All the associated fuses are fine as well.
Old Nov 10, 2011 | 11:21 AM
Greg00Coupe's Avatar
Greg00Coupe
My codes came and went for a few months and then they 1255 stayed. I did all the tests I could myself and decided to pull off the module this winter. Before I did that I took it to the dealer to confirm it is the EBCM which he did.
I just added this post yesterday......
http://forums.corvetteforum.com/c5-t...post1579182333
To HELP ABS code C1255
