Unique colum lock fix
Old Nov 11, 2011 | 11:34 PM
TRACKMAN2's Avatar
TRACKMAN2
Default Unique colum lock fix
have had tons of issues no les than 8 trips to the dealer...Brian says for some years he can change the 3 mph shut down to 225 mph so if it does trip nothing hapens. i dont think ill see 225 Mph any time soon
Old Nov 11, 2011 | 11:41 PM
'02magredZ51's Avatar
'02magredZ51
I've always wondered about that. I've seen it done for CAGS before and thought it would be a great option for the column lock issue. That is saying it doesn't actually lock up at 190... bad bad bad...
Old Nov 12, 2011 | 12:11 AM
TRACKMAN2's Avatar
TRACKMAN2
got my pin removed colum dosent "lock"
Old Nov 12, 2011 | 09:06 AM
captharley's Avatar
captharley
Cruising
Does anyone know a dealer or independent shop that will reset the cut off speed from 2.5 mph to something higher? 200 mph works. I've talked to the local dealer here and they have the capability to do it but will not because of the liability issue. I'm in the Raleigh Wake Forest area. North Carolina.
Old Nov 12, 2011 | 09:10 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
CLB has worked for me for 11 years...changing the cutoff can be done easily by anyone with HP tuners
Old Nov 12, 2011 | 09:42 AM
captharley's Avatar
captharley
Cruising
I just bought an 01 with 50K on it. Was totally unaware of the column lock issue until it happened the second day that I owned the car!! Have become well educated since. I have the Houston Corvette CLB on the way but would do the MPH change just as a backup. The car has had all the dealer recalls done and the pin has been removed so the column will not lock.
Old Nov 12, 2011 | 10:26 AM
tommie's Avatar
tommie
i have the corvettes of houston clb and the mph changed when my tune was done....
To Unique colum lock fix
