I tried to lube the splines on my axles today because they are making noise. Problem is, I could not get the nuts to budge. I was feeling like I was near braking the breaker bar. The just would not budge. Any tips?
They're on there pretty good. I just use PB blaster and an impact and they come right out. Hand tools probably not quite as much fun...maybe try some heat?
I typically use an impact also, but I wonder how hard that is on the CV joint and splines, etc. ?? Guess not too much worse than getting crazy with the load pedal.
I used the jack handel on the end of the breaker bar. It will come loose. Remember these are one time use nutts. The new replacement ones will be a different size also unless they have been changed before. You can find the socketts for these at Auto Zone for about $11.00 apiece.
You should be able to find the nut at a good auto supply store, such as NAPA etc.
Do not over tighten the nut on re install. Bring to proper torque with torque wrench. Torque @ 118 lb.ft. The nut requires a 32 mm deep well socket.
I have reused the axle spindle nut before w/out buying a new one but... I check different things on the car quite often to include the axle spindle nut.
There's no movement taking place in these splines! The nut locks the CV shaft tight against the hub. If there's noise, it can't be coming from the splines unless the nuts are loose. The only need to grease the splines is to aid in disassembly.
I agree with you 100% on that. It makes logical sense. But why are so many users getting rid of the clunk after they do this?
For better leverage, I use an 18" pipe as an extention when more leverage is needed.
Actually there can be movement in the splines. That has been a problem since the C4s and continues through the latest C6. The chinking noise that can be heard when starting out is due to the splined axle shaft moving inside the splined wheel bearing. I just had both axle shafts and rear wheel bearings replaced under warranty on my C6Z to get rid of the noise. If the wear gets bad enough you can get down near the rear wheel with the hub cover off and actually see the axle moving inside the bearing splines as the driver lets the clutch out.
I had the exact same problem on my 86.
Bill
I was not aware. How many vehicles built by GM(or anyone else for that matter) today use a system like this? One would think they would have it sorted out by now.
Bill
... and GM is not the only manufacturer to struggle with this. The tooling used to produce these parts requires periodic calibration. Sometimes they are not calibrated properly, sometimes they are not calibrated frequently enough. With enough tolerance drift/stack, you get an audible noise.
On one vehicle with which I am familiar, the manufacturer recommended coating the splines with red Loctite and then assembling the hub and then allowing the vehicle to sit overnight before driving. This was a very effective stop gap until the manufacturer identified and sorted out the root cause and then produced new, in-spec parts.
So long as you know that the Loctite is there, all that is required is a little patience and a few minutes with the hot wrench. Then it will come apart just like butter.
If the poor bastard trying to take it apart didn't know, then he would likely have a very bad day!
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Back in my younger days, I did a frame off (total body replacment) job on a CJ5 for a guy. It was then that I decided that Jeeps are the biggest pos every produced in automotive history.
During the job, I also did an engine build which was on a 304, way too much engine for a jeep. On a test drive, doing nothing more than driving the vehicle, I went to apply some throttle and something in the driveline gave. I hadn't even done anything? Had to stick it in 4wd to get it the 1/4 mile home to work on it.
Here, I had a spun a hub. Upon R & R, I get the new one and the shaft has splines, but the hub does not. ???? Wtf? Yea, so here's how they "designed" it. You take this hub, which is made from some crappy $h*& steel from china, stick the hub on on the shaft, then sit there with an impact wrench tightening this thing till the splines in the shaft smash their way into the tapered hub. And that's it. Go drive a while, it loosens up, and the next idiot jeep owner gets to do it again. Moral of the story is, don't drive anything designed by the pilgrims.
These vette ones may not be perfect, but they're much better than some.
