ignition switch
Old Oct 19, 2012 | 07:42 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Default ignition switch
Hi,
I'm having trouble on my 02 with the ignition switch. I replaced it with a new OEM switch but it's giving me the same trouble, it doesn't engage the solenoid. I've cleaned the key, changed keys, and sometimes I can lick it and it works-maybe coincidental. One time I must have tried a dozen times and almost ran out the battery before it fired and it was flooded by then. Another dozen times and it started running fine. I'm stuck.
Old Oct 19, 2012 | 08:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I dont understand your symptoms..
Are you saying that the starter runs but wont engage the flywheel OR Is the starter not working at all when you do everything to crank the engine???????????
BC
Old Oct 19, 2012 | 08:52 PM
lucky131969's Avatar
lucky131969
Do I understand correctly, that you actually lick the key with your tongue?
Old Oct 19, 2012 | 08:56 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Mike
You have never LICKED YOUR KEY??
MAN,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,, You dont know what your missing. Those resistor pellets taste like CHICKEN!!!
Old Oct 19, 2012 | 09:26 PM
lucky131969
Originally Posted by Bill Curlee
Mike
Ya know, I always wonder where the phrase "you really licked that problem" originated from. I didn't realize, that people were literally licking their problems. Have I been wasting my time with a meter and schematics all these years??
Old Oct 21, 2012 | 08:55 PM
The Rabbi's Avatar
The Rabbi
I was in the Army, I have a strong stomach. Water conducts electricity and can help make a connection if it's dirty.
Seriously, it's not clicking the solenoid. It doesn't make sense unless the new switch is junk which wouldn't surprise me. My mechanic ignores my suggestion that it could be corrosion at the solenoid connection. I'm prone to believe it's the switch again.
Old Oct 21, 2012 | 08:57 PM
The Rabbi's Avatar
The Rabbi
I know how to detail a car all the way. It's ALL clean.
Old Oct 21, 2012 | 09:11 PM
lucky131969
Plan on posting your codes??
Old Oct 21, 2012 | 09:54 PM
The Rabbi's Avatar
The Rabbi
Default switch
A vette shop told me to go to a dealer. Ugh. I'll check with my local mechanic and have him check the codes.
Old Oct 21, 2012 | 10:35 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
[QUOTE=The Rabbi;1582135203]I was in the Army, I have a strong stomach. Water conducts electricity and can help make a connection if it's dirty.
Seriously, it's not clicking the solenoid. It doesn't make sense unless the new switch is junk which wouldn't surprise me. My mechanic ignores my suggestion that it could be corrosion at the solenoid connection. I'm prone to believe it's the switch again.[/QUOTE
If you have WATER or even moisture on the Ignition Switch contacts,, MAN THE LIFE BOATS!
Remove the switch and conduct a resistance check on it. If it fails,, disassemble it and figure out what the exact is wrong and FIX IT.
BC
Old Oct 22, 2012 | 09:14 AM
The Rabbi's Avatar
The Rabbi
Default switch
[QUOTE=Bill Curlee;1582136138]
BC
Thanks for the video, Bill. Don't the codes mean something is wrong so how can you just delete them? Is it really possible that there is a code that occassionally prevents the key from making contact with the solenoid? I'm going to be near a dealer and will pick their brain about this problem. They must have experience with this problem.
Old Oct 22, 2012 | 09:16 AM
lucky131969
[QUOTE=The Rabbi;1582138136]
So. If you are not willing to post your codes, what is it that you seek from this forum?
Old Oct 22, 2012 | 09:29 AM
The Rabbi's Avatar
The Rabbi
Default switch
[QUOTE=lucky131969;1582138147]
Thanks Lucky but Bill didn't mention posting codes, just deleting so I don't know how to read the codes since the video was just about clearing them. So I'll have to write down the numbers, this is all new to me so have patience please. How do I get to read the codes?
Old Oct 22, 2012 | 09:37 AM
lucky131969
[QUOTE=The Rabbi;1582138228]
I'm at a loss. The video specifically details how to retrieve the codes, in a step by step fashion. If that does not make sense to you, perhaps you are better served, by taking your car to the dealer.....or trusted shop.
Old Oct 22, 2012 | 09:55 AM
The Rabbi's Avatar
The Rabbi
Default switch
[QUOTE=lucky131969;1582138281]
I missed that part but don't know what to do with the codes anyway so like you say I'll just take it to an expert. I'm not a mechanic by any means, just trying to find out what could cause the problem.
Old Oct 22, 2012 | 09:58 AM
lucky131969
[QUOTE=The Rabbi;1582138429]
That's the whole point of joining this forum. You retrieve your codes, and post them. Then forum members can assist you with troubleshooting. If you are not capable of doing the work yourself, then we can at least tell you the most likely problem.
Without the codes, all everyone can do is guess.
Old Oct 22, 2012 | 10:04 AM
The Rabbi's Avatar
The Rabbi
Default switch
[QUOTE=lucky131969;1582138449]
Thanks Lucky, that's what I needed to hear. I'll put the laptop on the seat and run Bill's video so I get it right.
To ignition switch
Old Oct 22, 2012 | 10:06 AM
lucky131969
[QUOTE=The Rabbi;1582138519]
You can print this out.....
http://www.c5forum.com/ayc/dtcdic.php
Old Oct 22, 2012 | 10:11 AM
wcsinx's Avatar
wcsinx
The Army trains people to moisten electrical contacts?
Seriously, it's not clicking the solenoid. ... I'm prone to believe it's the switch again.
Why/how have you eliminated the starter solenoid as a culprit?
Old Oct 22, 2012 | 04:05 PM
The Rabbi's Avatar
The Rabbi
Default switch
I didn't eliminate the solenoid but that's a possibility. I thought a solenoid either worked or didn't, no inbetween.
The dealer wants $189 to run diagnostics.
