i have a ls2 stroked to 403ci with the following mods, ported stock tb, fast 102 ported,fast 56lb injectors, ewp with 180 stat,25% ud pulley, tb spacer from 102mm to 90mm, vortex intake,catch can,b&b headers,exhaust,and mid pipe,trick flow 225cnc heads milled 10cc, and ported meiling oil pump and external trans cooler. 11.1 compression. no converter installed yet.
my temps are:
180-210 for the water (can i add the 160 stat for better temps?)
198-203 for trans
220-236 oil
Are these temps acceptable? I am still breaking in the engine and it only has 20 miles on it so far. will the oil temps go down after break in and i switch back to the royal purple 5w-30 full synthetic. I believe the oil in it now for break in period is 15w 40 or something close to that but is regular oil not the normal synthetic i use and was told to use by larry engine in tucson az who built the forged motor. So is there anything to worry about or any comments?
Forget the water pump part....didn't realize you're running an ewp.
I suggest upgrading to a dewitts radiator....
so are any of those temps high? what temps should i start worrying at?only thing added for cooling was a external trans cooler the b&m cooler 24,000 btu model.
