Drivers window regulator
Old Nov 14, 2011 | 04:28 PM
XLR8KWK's Avatar
XLR8KWK
Default Drivers window regulator
Last December I bought and installed an Eckler's aftermarket drivers window regulator. This week it gave up. Has anyone else had problems with this regulator, or did I just have bad luck? It never was as fast as the original going up.
I want to see if I should try again or just ante up for a factory unit.
Thanks!!
Old Nov 14, 2011 | 07:56 PM
Jumper11's Avatar
Jumper11
I got my door replaced after my wife ran into it. My window goes up and down fine but when it goes down and stops my volt meter goes down 3 to 5 volts for a second or two. Does you meter go down too.
Old Nov 15, 2011 | 08:43 AM
XLR8KWK's Avatar
XLR8KWK
No, my volt meter does not go down, but neither does the window now!
The old one was crunching and grinding, so i repalced it with the Eckler's unit. The new one was always slower than the factory unit.
Old Nov 15, 2011 | 08:50 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
What is it doing now? Will the window move and if so, is it making noise like a messed up regulator?
Old Nov 16, 2011 | 07:55 AM
XLR8KWK's Avatar
XLR8KWK
It is making grinding noises and does not go up or down correctly now. If i try to get it to go all the way up, it goes down. I am guessing that the cable is broken and wrapped the wrong way, so i need to get another regulator.
I am just trying to figure out if I got a bad one or if all the aftermarket (cheaper) ones are not as good as the factory unit.
Old Nov 16, 2011 | 08:26 AM
dgrant3830's Avatar
dgrant3830
I had to replace the regulator assembly in my '99 several months ago and I did use an OEM unit. I had no issues with it as its smooth, fast and quiet. Yes, put it in myself which is simple and of course re-adjusting the window took a whole 5 minutes.
To Drivers window regulator
