C5 2002 check engine light on
Old Nov 14, 2011 | 05:42 PM
quicksilver02's Avatar
quicksilver02
4th Gear
Default C5 2002 check engine light on
After not starting my 2002 for a couple of weeks,the car was dead so I plugged in the battery tender for a few hours ,than unplugged and started her up.I now have the check engine llight on and pulled all the codes from DIC but they are all history codes.How can I figure out if one of these history codes is the problem or could it be from the drained battery.These are the codes:BO432H BO502H B0503H BO507H BO508H B2482H B2483H B2587H B2592H B2282H B2284H B2262H B2283H B2285H U1064H BO851H U1255H. Thanks
Old Nov 14, 2011 | 05:52 PM
lucky131969's Avatar
lucky131969
Reset the codes, they are all history.
Old Nov 14, 2011 | 06:04 PM
quicksilver02
4th Gear
That will clear out the history of past codes as I understand it, but won't shut the check engine light?
Old Nov 14, 2011 | 06:06 PM
lucky131969
Give it a try...
Old Nov 14, 2011 | 06:09 PM
quicksilver02
4th Gear
OK Thanks I'll give it a try let you know
Old Nov 14, 2011 | 07:39 PM
quicksilver02
4th Gear
Went to clear codes but started it up first for the heck of it and no check engine light and went for a nice drive,turned it on and of a couple of times and it stayed off. I guess I'll just keep an eye on it
Old Nov 14, 2011 | 11:02 PM
abflyboy's Avatar
abflyboy
Those are most likely low system voltage related dtc's from when the car wouldn't start initially.
To C5 2002 check engine light on
