Cracked oil pan
Old Nov 15, 2011 | 07:11 PM
pcbunn's Avatar
pcbunn
Default Cracked oil pan
Think I have cracked my lower oil pan as remember running over a melon sized rock and now have weeping and drops into the pizza pan under the car. Anyone replaced the pan from under a set of race ramps? How hard is it? I'm up for trying it myself if its just a normal replacement issue without having to remove anything but the pan. The dealer wants $950 for the part new and another $200 to install, if its much trouble I'll just have them do it. Any advice is appreciated. Thanks
Old Nov 15, 2011 | 07:14 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
if you have to two piece pan you may get lucky and only need to replace the lower piece.
This happened to YeloFvr at the beach, something fell off a truck and knocked a hole in his. We pulled it up on a friends trailer and changed the lower piece.
If the hole isn't to bad you maybe able to take it to a weld shop and have them patch it for WAY less then buying a new one.
Old Nov 15, 2011 | 07:24 PM
pcbunn's Avatar
pcbunn
I think its just the lower one as the leak is coming from the front portion of the pan ahead of the plug. Havn't removed it yet untill I find out if I can do it myself with the car up on a set of raceramps and jacks in the back. If I can then once I have it off I can determine if it can be welded without warping it. Would be good if it can but got to get it off first. Do you know if average Joe like me can take it off and replace it without too much trouble? Thanks
Old Nov 15, 2011 | 07:55 PM
Greg_E's Avatar
Greg_E
If you have the time to look around, you can probably find a used pan or possibly a new crate engine take off for around $150.
Old Nov 16, 2011 | 12:07 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Used lower section is an EASY repair.. Yes,, you should be able to do it on ramps IF you have a TWO piece pan. The lower section comes off easy!
MAKE SURE that you follow the proper torque sequence and torque values for the pan bolts.
If you have to have a new one,, contact Gene Culley www.gmpartshouse.com He has the best prices on anything new GM Only.
Bill
Old Nov 16, 2011 | 12:19 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
what headers are those?
Old Nov 16, 2011 | 12:21 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
They are STAINLESS WORKS. The mid section is 3" from the collector to the muffler tips! FIT, and Performance is excellent/
Bill
Old Nov 16, 2011 | 12:24 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Nov 16, 2011 | 12:41 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
If it isn't just the lower piece, a C6 oil pan makes taking the headers off easier
Old Nov 16, 2011 | 02:08 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the above is true if lower pan. a 2 minute setup of some low angle ramps will verify what you need
If it's the entire pan.......the lower cradle will need to be removed; a pretty large job, GM makes a front plate that can support the motor
To Cracked oil pan
