Difference O2 sensor readings before and after cats?
Old May 6, 2002 | 11:02 PM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
Default Difference in O2 sensor readings before and after cats?
Does the exhaust going through the cats make much of a difference on the O2 readings? Does it add or subtract from the "real" O2 numbers? Most of the dyno shops use a tailpipe sniffer. How does that compare with using the sensor in front of the cats?
[Modified by FRISKY, 9:19 PM 5/6/2002]
Old May 8, 2002 | 11:04 PM
FRISKY's Avatar
FRISKY
Default Re: Difference in O2 sensor readings before and after cats? (FRISKY)
30,000 plus members on this forum and not one has an answer?
Old May 8, 2002 | 11:19 PM
Pigface1's Avatar
Pigface1
St. Jude Donor '03-'04-'05-'06-'07-'08
Hey Frisky. . . not a clue, but that thing will sound vicious w/out cats!
-Sean
Old May 9, 2002 | 01:11 PM
ersatz928's Avatar
ersatz928
The OBD2 computer looks at the difference between the pre and post OX sensors to determine if the cat is working. The signals are normally different if the cat is chemically "working". Removing the cats and retaining the 2 OX sensors will cause a check engine light.
Old May 9, 2002 | 03:00 PM
FRISKY's Avatar
FRISKY
Thanks for the answers guys but I'm not asking this because I want to remove the cats.
What I really want to know is the tailpipe O2 "sniffer" from the dyno shop giving me the same O2 readings as a sniffer put in the pipe before the cats? In other words, how accurate is a tailpipe sniffer?
To Difference O2 sensor readings before and after cats?
