upgrading to Z06 MAF?
The PCM wasn't tuned for it.
Car ran 14.3 @ 97 in the 1/4 mile.
Replaced with a stock MAF.
13.0 @ 107mph.
You will have change the airbridge piping to accomodate it.
And get the 3 wire to 5 wire conversion harness.
And have the PCM tuned.
All for probably no gain on a stock engine.
Ron
I appreciate the help
The real experts will chime in here on the H/C/Intake change.
But the Z06 also uses the 75mm TB.
I was told it's fine to a point. I don't know where the change over to larger needs to happen HP wise.
I also don't know if there is a larger TB that fits the LS6 intake manifold? Guys? The 90mm TB has a different bolt pattern. I suppose an adapter could be made.
Anyway, as long as you are doing H/C/intake, and will need a tune, might as well add the larger MAF in the process.
BTW, I'm in the same boat. After putting the correct MAF in mine, I have bought heads, cam, FAST intake, 90mm TB, headers etc. So I get to change all mine to the larger stuff too.
Ron
Pre-Z06, how much does TPI's usually charge for the 90mm upgrade?
If you go here:
http://www.ls1howto.com/index.php?article=25
You can get the Z06 (screened and unscreened) MAF table to input using HP tuners. Pretty excellent write up. Also talks about the diff from the 97-98 PCM vs. 99 up.
I found a used FAST 102 setup with the 90mm GM TB, rails, injectors and all the hardware that I'll pick up tomorrow. Came off a spotless C5, and well, intake manifolds don't wear out. Couldn't pass up the price. So it appears AutoX and I are on similar paths.
Ron
Anyone know a good place to find larger rubber coupler/joints to accomodate the larger MAF so I can bolt it to the K&N intake bridge and K&N filter?? I am assuming I will definitely need these as the 85mm LS6 maf OD is larger than my stock unit...
Andrew
If you're springing for an aftermarket intake and TB, I would go FAST92 with a LS2 tb. The BBK is worth a few over the LS6 but in my opinion heat soak is not worth it. I would spend money on an 80mm TB, gains are not worth it, IMO.
