RDCM code B2285H???
Old Nov 21, 2011 | 05:39 PM
TroyPyles's Avatar
TroyPyles
Default RDCM code B2285H???
All of a sudden the passenger window won't go down and the door won't lock with the button. I'm getting a B2285H code. Anyone know the problem?
I can check the grounds in the engine compartment but can't figure out where the grounds closer to the BCM might be. Any help there would be appreciated. I've seen the posted grounds diagram but it is not clear as to where the wires in the passenger compartment may be.
Old Nov 21, 2011 | 09:08 PM
TroyPyles's Avatar
TroyPyles
I did all the grounds I could find and they were already very clean. Problem still exists. Any ideas?
Old Nov 21, 2011 | 09:12 PM
Vicarious.'s Avatar
Vicarious.
http://forums.corvetteforum.com/c5-t...-batt-2-a.html
checked any fuses yet?
Old Nov 21, 2011 | 10:09 PM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by Ironembraced
Did you check the fuses that I mentioned in the previous thread linked above? Look for the easy things first. Then check the wiring in the accordian tube to see if there is a problem with it. Two of the grounds in the cabin are at the base of the A pillars on both sides of the car. The one for the passenger door will be behind the sill plate cover at the base of the pillar. Reference the document below to picture below to see what it looks like.
Bill
File Type: pdf
Old Nov 21, 2011 | 10:24 PM
TroyPyles's Avatar
TroyPyles
I did find that ground below the A pillar and it was clean as can be. I did not check the fuses. Not sure why, I did think about it. I'm headed to the garage not to see about that.
Old Nov 21, 2011 | 10:41 PM
TroyPyles's Avatar
TroyPyles
No luck. I checked both fuse 30 and 31 and they look fine. Problem still exists and the code cannot be reset.
Old Nov 21, 2011 | 10:45 PM
TroyPyles's Avatar
TroyPyles
Where is the Right Door Modual? Need to know to check the wiring between it and the fuse panel.
To RDCM code B2285H???
