I have seen this term used several times and at what HP does it start to effect the engines performance? Or even worse cause a lean cylinder.
Can you look at the plugs to see which ones are flowing more that the others to use those on the famous #5 & #7 cylinders that fail because they run lean?
I believe flow matched fuel injectors become a signficant factor while driving at high RPMs vs. high horsepower. A dyno session should tell you what your fuel injector duty cycle is so you know whether or not you're maxing out your current set of injectors and need to go a size bigger. You can lose a cylinder in a relatively low horsepower engine to a "leaned out" condition due to a poor tune - ask me how I know (I lost my original cammed LS1 years ago on a road course due to a poor dyno tune - factor of timing, A/F ratio and other parameters). My current set of injectors are "flow matched" because of how I run my engine - road courses.
On my current setup, I sent the injectors to New Era Performance for cleaning and flow testing. I then put the two highest in the rear two cylinders noting that the flow differences were actually quite small.
As an aside, my old 1990 L98 never started good when hot and it seems most of the L98's had this characteristic. I bought a set of flow matched Lucas disc injectors and the hot start problem went away. Note that I had done both a balance and leak test on the original injectors to ensure that wasn't the issue prior to buying the new set.
AlohaC5, I can see my inj duty with HPTuners and at WOT I'm at about 80% with mine. But what I don't know is what each cylinder is doing. This might be more of an issue as you push the inj toward 100% and having a cylinder go lean.
I had the unlucky 7 syndrome, searching never found answers.....some good theories.
One tuner suggested to me running fatter injectors on 5 & 7 would be corrected by the NB's...then when you tune with WB you are doing the same thing again. Kinda made sense to me.
It is a good idea to learn how to properly read plugs and start doing that. You can not only determine fueling, but timing as well. The guys in the nitrous section of Yellow Bullet are constantly reading and discussing plug reading. That's where I picked up the best information. Using a good tool to read them is highly important too. I use a 10x otoscope to read mine. You must know that you can't simply pull a plug and read it. You need to put a fresh plug in and make a pass and shut it down. Pull the plug and read it.
I agree! I learned that long time ago stock car racing changing jets chasing the cool night air. Infact looking at my plugs is what got my attention and noticing some cylinders richer than others.
