LS1 how to on cam install
Nov 25, 2011 | 05:53 AM
I've just read through the posts on cam installations and many posts suggest the LS1 how to procedure.
I'm not having any luck finding the article though. The links provided lead to a page that isn't a "how to".
Anyone have a good link to the procedure?
Nov 25, 2011 | 06:24 AM
ls1howto is down right now. Look like someone didn't pay to renew their domain.
Nov 25, 2011 | 06:43 AM
Ok thank you.
Specifically this is the link I have followed and the page it brings up didn't seem like the great cam install procedure I keep hearing about..
http://www.ls1howto.com/index.php?article=1
I assume if the site comes back up this link will work..
Nov 25, 2011 | 07:55 AM
You may be better off with it down. There are several steps on that site where those who followed it damaged their motors.
Nov 25, 2011 | 09:16 AM
St. Jude Donor '12, '15
Quote:
Originally Posted by
vettenuts
What would those steps be?????
Nov 25, 2011 | 10:12 AM
Nov 25, 2011 | 10:31 AM
Garys06Z06
the steps for the balancer install and removal. You really need the proper tool for that step. Get a factory service manual, it was a huge help when I did my H/C install
Nov 25, 2011 | 11:07 AM
I think a combination of service manual, a good write up with pictures and the myriad of posts here will be my best ticket.
Thank you for the link, for now I just scanned it but right away I'm surprised the most advised link on this board is for a non corvette.
Nov 25, 2011 | 01:10 PM
the c5 how2s are on the right side of the site #13 is the one you need to look at
Nov 27, 2011 | 01:08 AM
There are a couple of very good books out there which will help with far more than just a cam swap.
If you only buy one of these get this one. Great pictures.
How To Build And Modify GM LS-Series Engines by Joseph Potak
I also recommend Chevy LS1/LS6 Performance By Christopher P. Endres
The GM Service manuals are also a must have.
Good Luck.
Nov 27, 2011 | 05:12 PM
Buy the Hawk tool to install the balancer.
Nov 27, 2011 | 10:19 PM
Paul 75 L82
LS1 How to is pretty much spot on except for the instructions on installing your balancer. Doing it the way it instructs - you run the risk of stripping the threads and that's not good. Definitely pick up that balancer tool:
http://www.coloradospeed.com/index.p...ducts_id=10976
Other than that make sure you follow the LS1Howto instructions and use Corvette Forum for a source of info and you should be good to go.
balancer ,
c5 ,
cam ,
corvette ,
h0w ,
howto ,
install ,
long ,
ls1 ,
ls1howto ,
removalinstallation ,
swap ,
tech ,
tool ,
vette
