Transmission Woes
He has the transmission, torque tube and a box of parts. My garage buddy will do the job and I'll help. I build engines and transmissions, setup differentials and basically I have some pretty strong mechanical troubleshooting and repair abilities.
The garage guy wants to know about how long it will take to change out the transmission. We don't have a FSM and for this one job would rather not purchase one. (Although we will if necessary)The owner of the Vette doesn't have enough mechanical or electrical skilz to warrant him getting one. Wiper blade change would be a major job to him.
How long should it take to change out the transmission and do we just change the tranny or the whole assembly. We'll probably put in a clutch, pressure plate and bearing while we're in there.
I have changed the clutch on a similar vehicle......my 1980 Porsche 928 and had no problems. What do you all think this should take time wise. Thanks guys but I'm lost here. This is one of those Kentucky buddy, buddy jobs. The man with the Vette owns a body shop, I need about 1500 bucks worth of body work done to my 1989 Silverado and the garage guy owes me. He doesn't build engines and I do.
He replaced an engine in a 2003 Ford Lightning and I rebuilt it and we sold it complete for $4500.00. Those Ford guys are nuts.
Everyone will be busy but we're just trying to limit the amount of cash that changes hands. Thanks for any help and Merry Christmas.
Good luck
I'd say plan for 4 - 6 hours on a lift. I've done it on jackstands and it took 8 or 9 hours the first time...
Today 04:25 PM
Is it necessary to change everything like the old days or can just the clutch disk and the TOB be changed. Is it OK to resurface the flywheel or do we change it? Sorry about the questions but inquiring minds want to know.
, so I always recommend the service manual (for people like me), that do not possess the extensive wisdom you obviously do.
Thanks, that's the same reply that I'd typically give someone else but I really am pretty good at this stuff. As your screen name implies, maybe I'm just "Lucky".
I'll just bite the bullet and purchase it for myself. I didn't mean to sound like a know-it-all and I use the forums and their members' knowledge base quite a bit. I always appreciate the help. Since I retired a few months back I've been pretty busy helping some local folks with their car problems and maybe I was getting a bit cocky.
The mechanical/electrical aspect of cars has been my hobby for many years and although I try to be humble I rarely get into trouble. I keep forgetting that you all do not know me. This forum makes us all too much like one big, happy disjointed family.
Thanks again for all the help. I'll tell the owner it should take a couple of days and go from there.
I do occasionally get lucky.
I have removed an entire rear diff and trans assembly on an A4 in one hour on jackstands in my garage !!!!---The rusty exhaust took the longest to get apart !
Hardest part was getting it up in the air safely so I would feel comfortable working under it.
Watch the way the brake lines run and how they move when you drop the cradle/rear. You will need to set it up that way when putting it together or you'll have to drop it again to get the brake lines right. (This could be why it took the 3rd weekend)
http://www.alldatadiy.com/?gclid=COG...FRhCgwod2BlOZw
There are about 3 comments I'd make that might catch you.
You have to pull the console apart and remove the shifter so it's not catching as you drop the drivetrain. Easiest is to just pull the 4 bolts and take the shifter off the "shifter box". You would have to take apart the bolt at the back of the shifter box if you seperate the trans and torque tube. Search here for shifter alignment so you get it back together right.
Watch how much you lower the drivetrain because the engine can come up against the firewall and damage the firewall. There is a pic on the torque tube with this warning.
I personally found it easier to put the torque tube in by itself. The whole assembly was just not letting me easily hit the pilot bearing. You can just lift it into place and with one hand on the back of the torque tube you can just wiggle it around till it slides in. I don't see how it makes any difference assembly time wise because you will likely seperate the trans and tube anyways while it's apart.
Peter
