Torque tube bushings question
Old Dec 1, 2011 | 08:39 PM
Sinister-one's Avatar
Sinister-one
Default Torque tube bushings question
How can I tell if my torque bushings are going bad ??
I have a recurring rumbling sound when on the highway. And its only at high speeds.
Any thoughts ??
Old Dec 1, 2011 | 09:29 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Any thoughts ??
Usually the TT couplers cause drivetrain vibrations more than noise. Any vibrations along with the noise?
__________________
Old Dec 1, 2011 | 09:37 PM
Sinister-one
no vibrations, just the consistant humming rumbling noise.
Sure wish GM would have put some access panels at both ends of the torque tube for inspection purposes....
Old Dec 1, 2011 | 09:44 PM
Supporting Vendor
Rumbling noise is indicative of bearing going bad........
Old Dec 1, 2011 | 09:46 PM
Sinister-one
what bearing ?????
Old Dec 1, 2011 | 09:50 PM
Supporting Vendor
what bearing ?????
There are 2 bearings inside the TT. One in the front support and rear support bearings.
Old Dec 1, 2011 | 10:39 PM
Sinister-one
Oh nooooooooo !!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 1, 2011 | 10:41 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
The propshaft is actually supported by four bearings. The input shaft nose rides in the pilot bearing pressed into the end of the crankshaft. The other end of the input shaft has a bearing between the torque tube and the shaft. The rear bearing of the propeller shaft assembly is supported by a bearing and housing assembly. The bearing and housing assembly consists of a housing, internally splined hub, pilot bushings, O-rings, snap rings, a wave washer, and two ball type bearings. The bearing housing hub internal splines couple to the manual transmission splined input shaft.
Tire cupping can cause a noise that will exhibit a beat frequency that varies in amplitude while cruising in 6th gear.
Old Dec 1, 2011 | 10:57 PM
Its_Go_Time's Avatar
Its_Go_Time
He said the torque tube contains 2 bearings. And he's right.
Old Dec 1, 2011 | 11:09 PM
Eric D's Avatar
Eric D
Wrong! The torque tube contains 3 bearings. One on the front, two at the rear.
Old Dec 1, 2011 | 11:26 PM
LoneStarFRC's Avatar
LoneStarFRC
Any thoughts ??
Ray, I agree with Eric that tires are one possible suspect. Are you on runflats? How many miles on your tires? Any signs of abnormal wear? Some tires get harder and/or noisier as they age. I've had some Goodrich KDW2s that got noisy when they got a lot of miles on them.
Worth checking out.
Btw, if you ever do replace your couplers, I can highly recommend Six-Shooters from Prothane.
Old Dec 1, 2011 | 11:53 PM
lionelhutz's Avatar
lionelhutz
A wheel bearing could also cause a rumbling sound. Often, with a wheel bearing the sound will change when going around curves though.
Old Dec 2, 2011 | 08:38 AM
Sinister-one
You can't hear any of the noise at low speeds, 30-40mph. It's only at highway speeds when the noise comes into play....
Robert, I was thinking the same thing about the tires. I have michelin's and i fo believe they are runflats. And I am due for a new set of tires. I'll jack up the car this weekend and inspect the tires to see what i find.
All you guys are just a wealth of information !!
As for the couplers, I have an aluminum one for the rear and will be buying a prothane one for the front position.
Old Dec 2, 2011 | 09:28 AM
Eric D's Avatar
Eric D
Having a solid rear propshaft coupler is a bad idea and might be the cause of your issue. There is a very good chance that the front coupler is on its way out. Two stock couplers share the torsional load, removing one put 100% of the load through the remaining one. What speed and what gear is it the worst?
Old Dec 2, 2011 | 10:17 AM
SaberD's Avatar
SaberD
try driving on a different highway. it could be the road surface.
Old Dec 2, 2011 | 03:53 PM
Sinister-one
I don't have the "solid" coupler installed. I have it for when I'm ready to change out the couplers.
you can start to hear the noise at about 55mph or so.
Old Dec 2, 2011 | 04:00 PM
LoneStarFRC
I would take Eric's advice and not use a solid. Pony up for a second Prothane Six-Shooter and use them front and rear. I've had mine installed for several months and have no NVH issues at all.
To Torque tube bushings question
Old Dec 2, 2011 | 06:26 PM
WKMCD's Avatar
WKMCD
FWIW: Rick put the RPM poly bushings in my TT when he did the trans/diff/clutch. Nice pieces!
Old Dec 2, 2011 | 06:32 PM
lucky131969's Avatar
lucky131969
Those little gems are pricey, but then again, you wouldn't want to cheap out with your setup for sure....do it once...do it right.
Old Dec 2, 2011 | 08:29 PM
Its_Go_Time
Right you are Eric! And let this be a lesson to all the youngsters out there: don't drink and post, cuz you're bound to stick your foot into your ***!
