headl light buld replacement ? help
Old Dec 3, 2011 | 01:32 PM
bigjohn19136's Avatar
bigjohn19136
Default headl light buld replacement ? help
want to replace my bulbs with new ones is there any secret or tips to install thanks Big John
Old Dec 3, 2011 | 02:24 PM
bigjohn19136
i read the book ! thanks anyway
Old Dec 3, 2011 | 02:31 PM
lucky131969's Avatar
lucky131969
What book are you referring to?
Old Dec 3, 2011 | 02:33 PM
Vettmann17's Avatar
Vettmann17
Raise headlights and click switch back one click to shut off headlights and keep buckets up. Remove plastic shroud around buckets (three screws). Reach in behind assemby and you will feel the socket, give it 1/4 turn and the bulb with the socket should pop out. Simply replace bulb and reverse the steps. should take you 15 minutes max, very simple.
Old Dec 3, 2011 | 07:29 PM
Paul 75 L82's Avatar
Paul 75 L82
Thanks for the info.
To headl light buld replacement ? help
