2000 MN6 Drain Plug ???
Old Dec 4, 2011 | 11:07 PM
Binski's Avatar
Binski
Default 2000 MN6 Drain Plug ???
I just bought a 2000 FRC and am going through everything. The Manual trans does not have a drain plug. I have searched the forums and have seen not mention of this. I know that GM says that you never have to change the fluid but it shifts a little knotchy so I would like to change it with p/n 88861800. Am I missing something with respect to the drain??? Other treads in the forum mention a drain plug.
Thanks for the help. Jim
Old Dec 4, 2011 | 11:15 PM
lucky131969's Avatar
lucky131969
Are you sure about that?
http://forums.corvetteforum.com/c5-t...id-change.html
whowon's Avatar
whowon
It should be on the rear passenger side if I remember correctly.
Old Dec 4, 2011 | 11:29 PM
Binski's Avatar
Binski
I have had it on the lift twice to look for it. Will look again tomorrow. I have a plug that is clearly marked "FILL" ( about half way up the side of the trans) with just a 3/8 plug, no electrical connection. The electrical connection is much higher on the trans. I will look again but I did look pretty good last time. Thanks
Old Dec 4, 2011 | 11:37 PM
lucky131969
If you notice, the C5 in the procedure is a Z06, which is why it has a trans temp sensor as the fill plug. All Z06 and European export C5's, had a trans temp sensor in a manual.
Old Dec 4, 2011 | 11:52 PM
Binski's Avatar
Binski
I guess the ultimate question is, " have any been made without drain plugs" ??? I did check the passenger side. I can't believe I could have missed it, But it is possible. Thanks for the input. Jim
Old Dec 4, 2011 | 11:59 PM
lucky131969
Believe it.......
Old Dec 5, 2011 | 12:13 PM
Sinister-one's Avatar
Sinister-one
I have a 2000 FRC, and yes the trans drain plug is on the passenger side at the rear of the trans.
Old Dec 5, 2011 | 01:19 PM
Binski's Avatar
Binski
Thanks I guess I just didn't look at it closely enough. Jim
Old Dec 5, 2011 | 02:11 PM
Sinister-one
updated post with picture of drain plug location.
Old Dec 5, 2011 | 02:32 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
isn't it labeled Drain?
Old Dec 5, 2011 | 03:01 PM
Sinister-one
yes it is.....
To 2000 MN6 Drain Plug ???
