Needs some tips
Old Dec 7, 2011 | 07:04 AM
garrell.770's Avatar
garrell.770
Default Needs some tips
JUST INSTALLED A VOLANT COLD AIR SYSTEM ON A 98 C5, AND DEBAING OVER WHICH H-PIPE, OVER THE AXLE EXHAUST I WANT, BUT I AM CONSIDERING A $600.00 HPTUNEUP INCLUDING DYNO TIME. DOES ANYONE HAVE EXPERIENCE WITH THE HP TUNEUP. THE COMPANY I WILL USE ONLY DOES PERFORMANCE WORK ON GM LS VETTES AND TRUCKS. I AM FROM THE DAYS WHEN WE INSTALLED HEADERS, CHANGED CAMS, INTAKES, CARBS ON STRAIGHT AXLE CARS AND MID YEAR CARS. OWNED 20 CORVETTES AND Z28'S HAPPY HOLLIDAYS TO ALL, LANDSPEED RACER
Old Dec 7, 2011 | 07:08 AM
lucky131969's Avatar
lucky131969
I would save your money until you install headers, cam, etc. No need to pop $600 on a tune for an air filter/catback upgrade.
Old Dec 7, 2011 | 07:52 AM
Jewjenk's Avatar
Jewjenk
Why you SHOUTING?
Old Dec 7, 2011 | 12:41 PM
tiojames's Avatar
tiojames
Would also recommend an X configuration instead of an H.
Old Dec 7, 2011 | 01:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your MODS really dont justify an EXPINSIVE full tune and YEP,, find a good X pipe!
You already have an H pipe (as poorly as it is designed)
STOCK MIDPIPE:
Dont expect significant gains from those mods!! You might see 15 HP on a good day but 10-12 is the norm.
If your hell bent on a tune, pay the 100-150 bucks for a good mail order tune.
Some other easy bolt on stuff that you can consider to get a few more HP:
2001+ Intake manifold
Ported TB
Under drive pulley
The most bang for the buck are headers.
Example of an X pipe:
BC
Old Dec 7, 2011 | 01:41 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Welcome to the world of computer controlled muscle cars !!!!
I agree no need for a tune for just a CAI the ECM will learn out for the added airflow on it's own-just give it 50-75 miles of normal driving --These car are pretty finely tuned from the factory--On a bone stocker you may only see between 10-17 RWHP gains with a tune
Better to wait til you've done some more mods
When moving on to other mods a-- dyno tune is not practical on a car that is a D/D and an automatic especially---Dyno tuners run it up to 6000-6500 -check the timing and AFR only there and try to make the most HP there as they can----A "street driven tune" is much better-on an automatic---- they can adjust -firmness-TCC lockup-upshift and more importantly downshift shift points--they can adjust timing for driving in town on the freeway and even WOT--P/T fuel trims as well--- idle or surging issues---
Best of both worlds is a dyno shop that will do both the dyno runs and some street driveability tuning---
The stock "H" pipe is a joke---there is only like a 1" hole betwen the 2 sides-- An "X" pipe is much better as it helps to scavange the exhaust and can get you maybe 3-4 RWHP-- The sound of the X pipe is different---It gives your car a more throaty "race car" note rather than the overdone low flowmaster rumble we've all gotten used to---I love the sound of the x pipe !!!
If you like it loud---run it with NO mufflers --just the cats--Mine is that way--and to me its pefect !! You know about the corvette tax as a previous owner how we get dinged for like $1200 for a set of headers when the basic same set on a camaro is $350 !!!
My exhaust cost me $50 for a magniflow universal x pipe and $75 for welding and adding the axle back 3" pipes $125 total instead of most cat-backs that run from $400-$700
Other "bolt on easy" mods to consider---
1. 160* thermostat ( but wait til you get it tuned so they can re-set the fan settings ) otherwise its worthless
2. LS6 intake----worth about 10 15 honest RWHP ( a 98 still has the ls1 intake)
3. coolant bypass kit--not really able to measure HP but keeps the TB cooler
4. change wires if they are stock w/ TR-55 NGK plugs gapped at .040
5. clean the MAF with brakeclean (oiled air filters often foul the MAF wires)
6 get your T-Body profesionally ported---(Shaner is good) worth about 5-8 RWHP but throttle response is much improved
Good luck and happy C5'ing
To Needs some tips
