Ran my car at the drag strip this weekend.When i started to shift to 3rd the clutch pedal stayed on the floor,so the car would not go into 3rd.So i coasted across the line.Now i can not get the car in reverse,all other gears work fine.It has a stock clutch and stock master cylinder.I changed the fluid 3 weeks ago.I have got it into reverse twice since this happened.Also got under car to check reverse solenoid its not plugged up. The end that plugs up has been tie wraped up so it was not pluged up when i bought the car. Any help would be very nice THANKS. car is a 2003 z06 headers cam cold air
Which connector is unplugged based on the pic below?:
