LS1 Edit
Old May 8, 2002 | 05:18 PM
rozdesign's Avatar
rozdesign
Default LS1 Edit
Ok, what is it, I know it's a programmer but need more detail please.
Where do you get it?
How much?
What kind of hardware do you need?
Does it utilize a sentinel?
Any info would be appreceiated...
Old May 8, 2002 | 10:47 PM
415cid Goose's Avatar
415cid Goose
Default Re: LS1 Edit (rozdesign)
Look on this website. http://www.carputing.com
[Modified by 415cid Goose, 8:50 PM 5/8/2002]
Old May 8, 2002 | 11:34 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: LS1 Edit (415cid Goose)
Goose the web site is down.
Are you thinking about getting LS1 Edit?
I'm working on getting an evaluation copy.
Old May 9, 2002 | 12:25 AM
DUKE's Avatar
DUKE
Default Re: LS1 Edit (Gary2KC5)
I have the LS1edit and have re programmed my PCM. Was getting to be an old man waiting on Cole. So got Ease scanner, LS1edit and immediately raised the idle, raise TQ management to 400, set fans lower, etc. Working on gettin LTFT down some now. It has a learning curve but its going to be the coming thing. It lets you in the PCM...or your PCM. I just like the freedom to do it myself and not rely on a cookie cutter program. FREEDOM....as Braveheart said. :D
Old May 9, 2002 | 03:00 AM
C5Noir's Avatar
C5Noir
Default Re: LS1 Edit (DUKE)
LS1Edit will allow you to do everything TTS et al can. I just got mine today, changed turn on fans, tuned my SVOs, deleted rear o2 codes, etc. It's wicked cool :)
Old May 9, 2002 | 01:53 PM
bassfisher's Avatar
bassfisher
Check out http://www.ls1edit.com
Old May 9, 2002 | 05:42 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: LS1 Edit (C5Noir)
While I understand and encourage the enthusiasm :D, LS1-Edit doesn't allow you to tinker with every byte and continues to evolve. E.g., those with v1.04 will notice a bunch of new A4 features (among others) in v1.05. The question of exactly what functionality gap exists between the GM tools and LS1-Edit is still unanswered. That's just the way reverse engineering black boxes works.
Old May 10, 2002 | 11:50 AM
415cid Goose
Yes, I have LS1 edit.
To LS1 Edit
