LS7 flywheel info needed
Old Dec 11, 2011 | 07:47 PM
boilerdawg's Avatar
boilerdawg
Default LS7 flywheel info needed
recently i purchased a ls7 clutch from a forum member. the flywheel gm part number that i got with the clutch is 120496901. ive tried to look this number up on gm part sites and it doesnt come up. from what i can see the ls7 flywheel part number should be 12571611. anyone know anything about the flywheel i have? is it an ls7 flywheel? i was under the impression the ls7 flywheels where lighter...i think this is actually heavier than the ls6 flywheel. just by holding the 2 and comparing. appreciate any info or help here.
thanks
matt
Old Dec 11, 2011 | 08:25 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
thanks
matt
Matt, the flywheel number you show has too many numbers. Is this a cast in number on the flywheel?
Old Dec 11, 2011 | 08:32 PM
boilerdawg's Avatar
boilerdawg
yes its cast into the back of the flywheel it also has LUK stamped in it as well.........
Old Dec 11, 2011 | 08:42 PM
Eric D's Avatar
Eric D
If no one else chimes in I'll see what I can find for you while at work tomorrow.
Old Dec 11, 2011 | 09:36 PM
lucky131969's Avatar
lucky131969
Eric,
Unless something has changed, I believe the casting number and part number are different for the LS flywheels. I double checked my old LS1 flywheel, and the number cast into it, does not match the GM part number in the parts manual.
Old Dec 11, 2011 | 11:01 PM
Eric D's Avatar
Eric D
Originally Posted by lucky131969
Eric,
Yeah, I believe you are correct. What I can do is look the print up for the flywheel, The prints sometimes include the casting number. I can also get the nominal weight as well.
Old Dec 12, 2011 | 07:03 AM
boilerdawg's Avatar
boilerdawg
Thanks for the help! I really appreciate it.
Matt
Old Dec 13, 2011 | 09:54 AM
Eric D's Avatar
Eric D
Mass of LS7 to LS6/LS1 flywheel - LS7= 26.5 lbs - LS6/LS1= 25.1 lbs
If there is a Luk number for LS7 in casting it should be A1904974 or something like this.
For current LS6/LS1 flywheel part number, 12551348
For current LS7 the flywheel part number, 12571611
Hope this is of some help..
Old Dec 13, 2011 | 10:41 AM
boilerdawg's Avatar
boilerdawg
Fantastic help!! i think by what you describe i have a ls7 flywheel i just dont understand the dang goofy numbers on it.
To LS7 flywheel info needed
