Pulling Codes...How?
Old Dec 12, 2011 | 05:15 PM
RED LT4's Avatar
RED LT4
Default Pulling Codes...How?
I know I have done this before but can someone tell me again how to pull codes from the computer?
Old Dec 12, 2011 | 05:21 PM
hotwheels57's Avatar
hotwheels57
In the search window directly above, use keywords "pulling codes". You should find a thread titled "Conflicting Symptoms... Need Help Please!" Click on it.
Within that thread there is a post by Bill Curlee.
Once you have the codes, this site should guide you in the right direction...
http://www.stengel.net/diccodes.htm
Old Dec 12, 2011 | 11:31 PM
dougbfresh's Avatar
dougbfresh
OR GOOGLE it!
Old Dec 13, 2011 | 07:29 AM
runner140*'s Avatar
runner140*
Originally Posted by dougbfresh
OR GOOGLE it!
Old Dec 14, 2011 | 07:07 AM
dougbfresh's Avatar
dougbfresh
Google is actually better to find things on this site that the search function generally is.
Old Dec 14, 2011 | 11:44 AM
johnson-rod's Avatar
johnson-rod
Press and hold 'options' and tap 'fuel' 4 times.
Old Dec 14, 2011 | 01:53 PM
DeeGee's Avatar
DeeGee
Here ya go:
Corvette C5 Codes
The codes which are displayed on the Drivers Information Center (DIC) are called Diagnostic Trouble Codes (DTC). Each code has a prefix letter followed by 4 numbers and a further letter. After a fault has cleared and the car has run a number of ignition cycles without the fault present, an "H" suffix for history will be set. Anything which is still has an active fault will have a "C" or current suffix. It is possible to see the suffix HC which can be set with an intermittent fault.
To enter the diagnostics mode turn the ignition key ON but don't start the engine. Clear any DIC messages (such as Door Ajar) by pressing the RESET button then push and hold the OPTIONS button and press the FUEL button 4 times.
Once the diagnostics begin the computer displays the codes which have been set since the system was last cleared down. It will visit each of the 11 sections in turn and cycle through each code (both H & C) every 3 seconds. The list displays in the following order:
10 - PCM - Powertrain Control Module
28 - TCS - Traction Control System
38 - RTD - Real Time Damping
40 - BCM - Body Control Module
60 - IPC - Instrument Panel Cluster
80 - Radio
99 - HVAC - Heater, Ventilation, Air Conditioning
A0 - LDCM - Left Door Control Module
A1 - RDCM - Right Door Control Module
A6 - SCM - Seat Control Module
B0 - RFA - Remote Function Actuator
Write the codes down for reference because often you’ll want to reset the codes to see which return.
To clear the codes, wait until the computer has cycled through every section. Press RESET to enter Manual Configuration. If it shows a code, press and hold RESET until it displays "NO CODES". If no fault is present in a particular section it will already show "NO CODES" or "# CODES". Work through each section until you clear the system. Turn the ignition switch OFF to exit diagnostics mode.
U codes set when there are power interruptions and are often present and generally are nothing to worry about. They set when you have battery issues or you change batteries but if you have power gremlins expect to see U codes.
Here’s a full list of the codes:
10- PCM - Powertrain Control Module
• P0101 Mass Air Flow (MAF) System Performance
• P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
• P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
• P0107 Manifold Pressure (MAP) Sensor Circuit Low Voltage
• P0108 Manifold Pressure (MAP) Sensor Circuit High Voltage
• P0112 Intake Air Temp (IAT) Sensor Circuit Low Voltage
• P0113 Intake Air Temp (IAT) Sensor Circuit High Voltage
• P0117 Engine Coolant Temp (ECT) Sensor Low Voltage
• P0118 Engine Coolant Temp (ECT) Sensor High Voltage
• P0118 Engine Coolant Temperature (ECT) Excessive Time to Closed Loop Fuel Control
• P0131 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1
• P0132 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1
• P0133 Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
• P0134 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1
• P0135 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1
• P0137 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
• P0138 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2
• P0140 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
• P0141 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 2
• P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
• P0152 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1
• P0153 Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
• P0154 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1
• P0155 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
• P0157 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2
• P0158 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2
• P0160 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2
• P0161 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
• P0171 Fuel Trim System Lean Bank 1
• P0172 Fuel Trim System Rich Bank 1
• P0174 Fuel Trim System Lean Bank 2
• P0175 Fuel Trim System Rich Bank 2
• P0230 Fuel Pump Control Circuit
• P0300 Engine Misfire Detected
• P0325 Knock Sensor (KS) System
• P0327 Knock Sensor (KS) Circuit Front
• P0332 Knock Sensor (KS) Circuit Rear
• P0335 CKP Sensor Circuit
• P0336 CKP Sensor Circuit Performance
• P0341 CMP Circuit Performance
• P0342 CMP Sensor Circuit Low Voltage
• P0343 CMP Sensor Circuit High Voltage
• P0351 Ignition Control #1 Circuit
• P0352 Ignition Control #2 Circuit
• P0353 Ignition Control #3 Circuit
• P0354 Ignition Control #4 Circuit
• P0355 Ignition Control #5 Circuit
• P0356 Ignition Control #6 Circuit
• P0357 Ignition Control #7 Circuit
• P0358 Ignition Control #8 Circuit
• P0410 AIR System
• P0412 AIR Solenoid Relay Control Circuit
• P0418 AIR Pump Relay Control Circuit
• P0420 TWC System Low Efficiency Bank 1
• P0430 TWC System Low Efficiency Bank 2
• P0441 EVAP System No Flow During Purge
• P0461 Fuel Level Sensor 1 Circuit Performance
• P0462 Fuel Level Sensor 1 Circuit Low Voltage
• P0463 Fuel Level Sensor 1 Circuit High Voltage
• P0480 FC Relay 1 Control Circuit
• P0481 FC Relay 2 and 3 Control Circuit
• P0500 VSS Circuit (M/T)
• P0506 Idle Speed Low
• P0507 Idle Speed High
• P0522 Engine Oil Pressure Sensor Circuit Low Voltage
• P0523 Engine Oil Pressure Sensor Circuit High Voltage
• P0530 A/C Refrigerant Pressure Sensor Circuit
• P0562 System Voltage Low
• P0563 System Voltage High
• P0567 Cruise Resume Circuit
• P0568 Cruise Set Circuit
• P0571 Cruise Brake Switch Circuit (M/T)
• P0601 PCM Memory
• P0602 PCM Not Programmed
• P0604 PCM RAM Performance
• P0606 PCM Internal Communication Interrupted
• P0608 VSS Output Circuit
• P0650 MIL Control Circuit
• P0654 Engine Speed Output Circuit
• P0704 Clutch Switch Circuit (M/T)
• P0705 Transmission Range Switch Circuit (A/T)
• P0706 Transmission Range Switch Performance (A/T)
• P0801 Reverse Inhibit Solenoid Control Circuit (M/T)
• P0803 1-4 Upshift Solenoid Control Circuit (M/T)
• P0804 1-4 Upshift Lamp Control Circuit (M/T)
• P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
• P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
• P1114 ECT Sensor Circuit Intermittent Low Voltage
• P1115 ECT Sensor Circuit Intermittent High Voltage
• P1120 TP Sensor 1 Circuit
• P1125 APP System
• P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
• P1134 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
• P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
• P1154 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
• P1220 TP Sensor 2 Circuit
• P1221 TP Sensors 1, 2 Performance
• P1258 Engine Coolant Over Temperature-Fuel Disabled
• P1275 APP Sensor 1 Circuit
• P1276 APP Sensor 1 Circuit Performance
• P1280 APP Sensor 2 Circuit
• P1281 APP Sensor 2 Circuit Performance
• P1285 APP Sensor 3 Circuit
• P1286 APP Sensor 3 Circuit Performance
• P1380 EB (T) CM DTC Detected- Rough Road Data Unusable
• P1381 Misfire Detected - No EB (T) CM/PCM Serial Data
• P1415 AIR System Bank 1
• P1416 AIR System Bank 2
• P1431 Fuel Level Sensor 2 Circuit Performance
• P1432 Fuel Level Sensor 2 Low Voltage
• P1433 Fuel Level Sensor 2 High Voltage
• P1441 Evaporative Emissions (EVAP) System Flow During Non-Purge
• P1514 TAC System MAF Performance
• P1515 Command vs Actual Throttle Position Performance (PCM Module)
• P1516 Command vs Actual Throttle Position Performance (TAC Module)
• P1517 TAC Module Processor
• P1518 PCM to TAC Module Serial Data Circuit
• P1539 A/C Clutch Status Circuit High Voltage
• P1545 A/C Clutch Relay Control Circuit
• P1546 A/C Clutch Status Circuit Low Voltage
• P1571 ASR Desired Torque
• P1574 Stop Lamp Control Circuit
• P1575 Extended Travel Brake Switch Circuit High Voltage
• P1626 Theft Deterrent System Fuel Enable Circuit
• P1630 Theft Deterrent System PCM In Learn Mode
• P1631 Theft Deterrent System Password Incorrect
• P1635 5 Volt Reference #1 Circuit
• P1639 5 Volt Reference #2 Circuit
• P1644 Delivered Torque Output Circuit
• P1652 Powertrain Induced Chassis Pitch Output Circuit
28-TCS - Traction Control System
• C1214 Sol Valve Relay Contact or Coil CKT Open
• C1217 BPMV Pump Motor Relay Contact CKT Open
• C1221 LF Wheel Speed Sensor Input Signal is 0
• C1222 RF Wheel Speed Sensor Input Signal is 0
• C1223 LR Wheel Speed Sensor Input Signal is 0
• C1224 RR Wheel Speed Sensor Input Signal is 0
• C1225 RF Excessive Wheel Speed Variation
• C1226 LF Excessive Wheel Speed Variation
• C1227 LR Excessive Wheel Speed Variation
• C1228 RR Excessive Wheel Speed Variation
• C1232 LF Wheel Speed Circuit Open or Shorted
• C1233 RF Wheel Speed Circuit Open or Shorted
• C1234 LR Wheel Speed Circuit Open or Shorted
• C1235 RR Wheel Speed Circuit Open or Shorted
• C1236 Low System Supply Voltage
• C1237 High System Supply Voltage
• C1241 Magna Steer Circuit Malfunction
• C1242 BPMV Pump Motor Ground Circuit Open
• C1243 BPMV Pump Motor Stalled
• C1255 EBTCM Internal Malfunction
• CEBCM Internal Malfunction
• C1261 LF Inlet Valve Solenoid Malfunction
• C1262 LF Outlet Valve Solenoid Malfunction
• C1263 RF Inlet Valve Solenoid Malfunction
• C1264 RF Outlet Valve Solenoid Malfunction
• C1265 LR Inlet Valve Solenoid Malfunction
• C1266 LR Outlet Valve Solenoid Malfunction
• C1267 RR Inlet Valve Solenoid Malfunction
• C1268 RR Outlet Valve Solenoid Malfunction
• C1273 RF TCS Master Cyl Isolation Valve Malfunction
• C1274 RF TCS Prime Valve Malfunction
• C1276 Delivered Torque Signal CKT Malfunction
• C1277 Requested Torque Signal CKT Malfunction
• C1278 TCS Temporarily Inhibited By PCM
• C1281 Steering Sensor Uncorrelated Malfunction
• C1286 Steering Sensor Bias Malfunction
• C1287 Steering Sensor Rate Malfunction
• C1291 Open Brake Lamp Sw Contacts During Deccel
• C1293 DTC C1291/C1292 Set Curnt/Prev Ign Cylce
• C1294 Brake Lamp Switch Circuit Always Active
• C1295 Brake Lamp Switch Circuit Open
• U1016 Loss of Communications with PCM
• U1255 Generic Loss Communications
• U1300 Class 2 Circuit Shorted to Ground
• U1301 Class 2 Circuit Shorted to Battery
38-RTD - Real Time Damping
• C1650 ESC Module Malfunction
• C1658 EEPROM Calibration Malfunction
• C1710 LF Shock Absorber Solenoid (Short to Voltage)
• C1711 LF Shock Absorber Solenoid (Short to GND)
• C1712 LF Shock Absorber Solenoid (Open Circuit)
• C1715 RF Shock Absorber Solenoid (Short to Voltage)
• C1716 RF Shock Absorber Solenoid (Short to GND)
• C1717 RF Shock Absorber Solenoid (Open Circuit)
• C1720 LR Shock Absorber Solenoid (Short to Voltage)
• C1721 LR Shock Absorber Solenoid (Short to GND)
• C1722 LR Shock Absorber Solenoid (Open Circuit)
• C1725 RR Shock Absorber Solenoid (Short to Voltage)
• C1726 RR Shock Absorber Solenoid (Short to GND)
• C1727 RR Shock Absorber Solenoid (Open Circuit)
• C1743 Loss of Vehicle Speed Signal
• C1760 LF Position Sensor (Out of Range)
• C1761 RF Position Sensor (Out of Range)
• C1762 LR Position Sensor (Out of Range)
• C1763 RR Position Sensor (Out of Range)
• C1768 Position Sensor Supply Malfunction (Overcurrent)
• C1780 Loss of Steering Position Signal
• C1786 RTD Control Relay Malfunction
• C1787 RTD Control Relay Circuit (Open or Short to GND)
• C1788 RTD Control Relay Circuit (Short to Voltage)
• C1790 Ride Control Switch (Out of Range)
• C1791 Ride Control Switch (Contact Malfunction)
40-BCM -Body Control Module
• B0432 Rear Defogger Relay Circuit
• B0433 Rear Defogger Relay Circuit
• B0502 RH DRL Relay Circuit
• B0503 RH DRL Relay Circuit
• B0507 LH DRL Relay Circuit
• B0508 LH DRL Relay Circuit
• B0605 BCM Internal Memory Function
• B0844 BCM Temporarily Inhibit ABS
• B2403 Front Fog Lamp Switch Circuit
• B2408 Rear Fog Lamp Switch Circuit
• B2482 Backup Lamp Relay Circuit
• B2483 Backup Lamp Relay Circuit
• B2527 Horn Relay Circuit
• B2528 Horn Relay Circuit
• B2573 Hatch Release Switch Circuit (Short to Voltage)
• B2578 RF Turn Signal Monitor Circuit (Short to Voltage)
• B2583 LF Turn Signal Monitor Circuit (Short to Voltage)
• B2587 Column Lock/Unlock Drive (A)
• B2588 Column Lock/Unlock Drive (A)
• B2592 Column Lock/Unlock Drive (B)
• B2583 Column Lock/Unlock Drive (B)
• B2597 Traction Control System Switch Circuit
• B2721 PASS-Key Detection Circuit
• B2722 PASS-Key Detection Circuit
• B2723 PASS-Key Detection Circuit
• B2735 PASS-Key Programming Mode Active
• U1096 Loss of Communications with IPC
• U1255 Serial Data Line Malfunction
60-IPC - Instrument Panel Cluster
• B0516 Speedometer Signal Circuit Malfunction
• B0521 Tachometer Signal Circuit Malfunction
• B1512 DIC Switch 1 Signal Short to GND "FUEL"
• B1517 DIC Switch 2 Signal Short to GND "GAGES"
• B1522 DIC Switch 3 Signal Short to GND "TRIP"
• B1527 DIC Switch 4 Signal Short to GND "OPTIONS"
• B1532 DIC Switch 5 Signal Short to GND "E/M"
• B1537 DIC Switch 6 Signal Short to GND "RESET"
• B1542 Oil Temperature Circuit Short to GND
• B1543 Oil Temperature Circuit Open
• U1040 Loss of Communications with TCS
• U1056 Loss of Communications with RTD
• U1064 Loss of Communications with BCM
• U1128 Loss of Communications with Radio
• U1153 Loss of Communications with HVAC
• U1160 Loss of Communications with LDCM
• U1161 Loss of Communications with RDCM
• U1166 Loss of Communications with SCM
• U1176 Loss of Communications with RFA
80-Radio - Radio Not Found
99-HVAC - Heater, Ventilation, Air Conditioning
• B0332 Outside Air Temp Sensor Short to GND
• B0333 Outside Air Temp Sensor Open
• B0337 Inside Air Temp Sensor Short to GND
• B0338 Inside Air Temp Sensor Open
• B0348 Sunload Temperature Sensor Open
• B0361 Left Actuator Feedback Short to GND
• B0363 Left Actuator Feedback Open
• B0365 Right Actuator Feedback Short to GND
• B0367 Right Actuator Feedback Open
• B0441 Left Actuator Out of Range
• B0446 Right Actuator Out of Range
• B1016 Loss of Communications with PCM
A0-LDCM - Left Door Control Module
• B2202 Left Window Up Switch Fault
• B2204 Left Window Down Switch Fault
• B2206 Right Window Up Switch Fault
• B2208 Right Window Down Switch Fault
• B2222 LT Mirror Select Switch Fault
• B2224 RT Mirror Select Switch Fault
• B2226 Mirror Right Switch Fault
• B2228 Mirror Left Switch Fault
• B2232 Mirror Up Switch Fault
• B2234 Mirror Down Switch Fault
• B2236 Left Door Lock Switch Fault
• B2238 Left Door UnLock Switch Fault
• B2242 Memory 1 Switch Fault
• B2244 Memory 2 Switch Fault
• B2252 Key Cylinder Switch Fault
• B2262 Horizontal Position Sensor Fit
• B2264 Vertical Position Sensor Fault
• B2272 Left Mirror Motor Fault
• B2274 Window Motor Fault
• B2276 Door Lock Motor/Mirror Heater Fit
• B2282 Battery #1 Fault
• B2284 Battery #2 Fault
• B2286 +5V Reference Fault
A1-RDCM - Right Door Control Module
• B2203 Right Window Up Switch Fault
• B2205 Right Window Down Switch Fault
• B2237 Right Door Lock Switch Fault
• B2239 Right Door Un-Lock Switch Fault
• B2253 Key Cylinder Switch Fault
• B2263 Horizontal Position Sensor Fit
• B2265 Horizontal Position Sensor Fault
• B2273 Right Mirror Motor Fault
• B2275 Window Motor Fault
• B2277 Door Lock Motor/Mirror Heater Fit
• B2283 Battery #1 Fault
• B2285 Battery #2 Fault
• B2287 +5V Reference Fault
A6-SCM - Seat Control Module
• B0846 Battery 2 Out of Range
• B0851 Battery 1 Out of Range
• B2002 Fore/Aft Seat Motor Open or Short to GND
• B2007 Front Vertical Seat Motor Open or Shorted
• B2012 Rear Vertical Seat Motor Open or Shorted
• B2172 Seat Front Up Switch Shorted to GND
• B2177 Seat Front Down Switch Shorted to GND
• B2182 Seat Rear Up Switch Shorted to GND
• B2187 Seat Rear Down Switch Shorted to GND
• B2192 Seat Forward Switch Shorted to GND
• B2197 Seat Reverse Switch Shorted to GND
• B2605 Seat Front Vertical Position Sensor Failure
• B2606 Seat Rear Vertical Position Sensor Failure
• B2607 Seat Horizontal Position Sensor Failure
B0-RFA - Remote Function Actuation
• B0605 Receiver Internal Memory Malfunction
• B2805 No Transmitters Programmed
• C2100 Left Front TPM Sensor Malfunction
• C2105 Right Front TPM Sensor Malfunction
• C2110 Right Rear TPM Sensor Malfunction
• C2115 Left Rear TPM Sensor Malfunction
• C2120 TPM System Malfunction (No Sensors Received)
• C2121 TPM System Programming Malfunction (No Sensors Programmed)
• U1000 Loss of Communication Undetermined
• U1016 Loss of Communication with PCM
• U1064 Loss of Communication with BCM
• U1096 Loss of Communication with IPC
________________________________________
To Pulling Codes...How?
