abs/traction
Old Dec 15, 2011 | 11:06 AM
wagner262's Avatar
wagner262
Default abs/traction
so i have had the problem for a while.... C1232 LF Wheel Speed Circuit Open or Shorted. but for some reason it seems to come on less and less. I can now drive past 60mph with out the car slowing down. i havent done anything. the only time the code comes on is when im going 30mph plus and hit a bump in the road hard. I know my rear shocks are blown and im guessing my fronts are getting there. would my shocks have to do with this code coming on? The bump causes the short? I used to get C1225 RF Excessive Wheel Speed Variation but dont anymore even after the abs/traction light come on. I just bought 4 new shocks to do over christmas break from college and im wondering if this will stop the lights from coming on?
Old Dec 15, 2011 | 01:53 PM
cliff_ford's Avatar
cliff_ford
C1225 is LF, some lists are wrong. Check the pins are not flattened in the female connectors at each end of the wheel harness.
Old Dec 15, 2011 | 02:14 PM
wagner262's Avatar
wagner262
i check them and they looked fine in my opinion. ive switched front right to left front and thats when i got 1225... but that was last winter and i havent seen that code for a while now....
Old Dec 15, 2011 | 03:43 PM
cliff_ford's Avatar
cliff_ford
The pins should look like the ones on the left. The right hand ones are worn.
Old Dec 15, 2011 | 03:58 PM
wagner262's Avatar
wagner262
heres my old one that was giving the code but it looks fine. i replaced it with another used one
Old Dec 15, 2011 | 07:29 PM
lucky131969's Avatar
lucky131969
Fine? One contact looks corroded to me.
Old Dec 15, 2011 | 07:42 PM
02koolC5's Avatar
02koolC5
Old Dec 15, 2011 | 07:55 PM
C5FORFUN2's Avatar
C5FORFUN2
I unplugged all mine, cleaned them and applied dielectric grease on them. Put them all back together and haven't had a problem since. (4 years driven daily, rain or shine.)
Old Dec 16, 2011 | 04:42 PM
wagner262's Avatar
wagner262
wow see i never understood how you could tell if its bad now looking at that picture it looks horrible lol. well when i do my suspension this winter i will also clean all of my speed harnesses! thanks guys. this has to be the problem!
To abs/traction
