Mantic single clutch from ECS
Old Sep 28, 2012 | 09:18 AM
bontrager's Avatar
bontrager
Originally Posted by 6.0vette
I've had it for over 5,000 miles now and have zero complaints!!! Drives like a stock ls7 clutch but holds A hell of alot more power. You won't have any regrets.......it's the best clutch I've ever owned barnone!!!!!!!
I'm thinking of having the Mantic single disc clutch installed in my 2000 vert.
Only 19,000 miles on the car. Is there any advantage to having the slave unit and the other hydraulics changed at the same time?
Don't want to spend extra if I don't have to.
Thank you.
Old Sep 28, 2012 | 09:50 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Thank you.
We would recommend changing the slave since it is removed to do the clutch anyway, but is very labor intensive to change by itself later if needed.
The master is easily changed at any time, and chances are both are fine, so I would leave that alone.
Old Sep 28, 2012 | 09:51 AM
nullpointer's Avatar
nullpointer
Can you use the twin disc with a tick adj master? any shimming needed?
Old Sep 28, 2012 | 10:47 AM
DOUG @ ECS's Avatar
DOUG @ ECS
The stack hight of the clutches is correctly made for each model C5/C6 so no need for shimming. A tick master can certainly be used, but most just use the stock master.
Old Sep 28, 2012 | 08:18 PM
FRiCK916's Avatar
FRiCK916
How would this compare to the monster 2? I bought the whole kit with lighter fly/tick master ect and now have a blower, it's not gonna hold... This clutch has my interest!
Old Sep 29, 2012 | 09:29 AM
DOUG @ ECS's Avatar
DOUG @ ECS
I cannot speak for the Monster good or bad, but I am positive the Mantic will work fantastic for your needs. I would recommend the 9000 series twin for a higher HP car.
