ac compressor, bracket, LS3 swap
Old Dec 16, 2011 | 10:44 AM
o1Z0sick's Avatar
o1Z0sick
Default ac compressor, bracket, LS3 swap
Tried bolting up my LS6 ac bracket but it looks like a no go fitting up to the LS3 block. I was wondering if anyone else has had this problem? I was very much unaware of this being a problem and I have done a lot of research. Searching here I can't find mention of this and/or a fix.
If the LS6 bracket does not fit I will need a LS2,3 bracket but then the ac compressor will need to be a LS2,3, which requires specific side mounted high/low pressure lines.
I could just get the LS2,3 bracket and compressor but the pressure lines will not work. Please help, what are my options?
Old Dec 16, 2011 | 10:51 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Swapped in many an LS3 into C5's now, never had an issue with the AC brackets? They bolt right in, just some motor mount fitment needs to be done.
Old Dec 16, 2011 | 11:06 AM
o1Z0sick's Avatar
o1Z0sick
Thanks Doug,
I will give it another try tonight and post a picture if I am still having problems. This should be easy compared to building the short block myself.
Old Dec 18, 2011 | 07:15 PM
o1Z0sick's Avatar
o1Z0sick
Had a brain fart or something because it definitely fits. Thanks for the feedback Doug.
Old Dec 19, 2011 | 01:47 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Anytime, glad I could help.
To ac compressor, bracket, LS3 swap
