lg headers install
Old Dec 19, 2011 | 01:01 PM
geogolf's Avatar
geogolf
Default lg headers install
anyone that has installed lg headers on a 99 frc chime in, do I need to use all 4 o2 sensors or can I get rid of the rear o2 sensors on mid-pipe thanks geo. new to c5 world so be gentle
Old Dec 19, 2011 | 01:46 PM
lucky131969's Avatar
lucky131969
You don't need to use 4 O2 sensors on any header system. Moving the rears to the front positions is the preferred method with LGs.
Old Dec 19, 2011 | 01:59 PM
99Vision's Avatar
99Vision
Waitin on lg streets to install on my 99frc right now.. The only thing im concerned with is the air tube on the passenger side. Ive decided to eliminated the air pum assembly so im thinkin ill have to get some blocker plates..
Old Dec 19, 2011 | 02:04 PM
geogolf's Avatar
geogolf
Default rear o2
lucky thanks for the reply do I just put plugs in the rear bungs or what thanks geo.
Old Dec 19, 2011 | 02:07 PM
lucky131969
Yep, plug the rear bungs and order adpaters from LG, so the rears will plug into the front harness. Have your tuner turn off the codes.
Old Dec 19, 2011 | 02:08 PM
geogolf's Avatar
geogolf
Default air hose
99 that also my problem, the headers I bought are from a 01/03 models so I need a dipstick tube also, I looked at the airhose I might just cut it with a cutter and get a good peice of rubber hose to hook between the 2 ends for now
lucky131969
Originally Posted by 99Vision
...so im thinkin ill have to get some blocker plates..
Yep.
Old Dec 19, 2011 | 02:12 PM
geogolf's Avatar
geogolf
Default headers
thanks lucky from the pics of headers, the harness and adapters might be included gotta wait till they get here and check it out geo.bought them on flebay headers/high flow cats midpipe with xpipe for 680 once I get everything put on[ also have 410 rear to install] I am going to send pcm to ecs for a tune
To lg headers install
