Cannot Figure out this Engine Noise!!!
Old Dec 16, 2011 | 10:43 PM
Dtownbrown's Avatar
Dtownbrown
Default Cannot Figure out this Engine Noise!!!
Just had an engine built *408 stroker / 4'' crank, eagle h beam rods, JE turbo pistons , bullet reverse duration turbo cam, 6.0 heads. All professinally built and put together except I installed the pushrods/rocker arms/ clutch/ oil pump,pickuptube, and pan. And from the first start up there is this deep knocking sound. it not a fast ticking or clattering sound. I could feel the knock when I placed my hand on the oil pan. The engine Idles and revs up fine, but when accelerating the knock does get fast with the rpms. So im not sure if maybe somehow I could have not installed something right? maybe the crank could be hitting the oil pan trey?( yes I put the washers inbetween the trey and bolts) Or maybe a lifter has failed? But i wouldnt think you could feel a lifter from the oil pan? Not sure if maybe the pickup tube could be getting hit? I got plenty of oil pressure. Not much of a way to figure it out without having to start tearing bits and peices off untill I find it. Anyone have any experience with strange knocks?
Old Dec 17, 2011 | 12:09 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Was the engine bar'd over after the oil pan, windage tray installed? What does your engine builder suggest? Any deep knock noise is NOT good. I would suggest not running it anymore until to cause is identified.
I would start by pulling all the plugs and barring over and see if you feel/hear something.
Old Dec 17, 2011 | 12:30 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I would get that oil pan back off and start checking things.
Old Dec 17, 2011 | 12:40 PM
nagroves's Avatar
nagroves
6th Gear
I would guess a lifter, but check your oil pan as well...
Old Dec 17, 2011 | 01:17 PM
RonSSNova's Avatar
RonSSNova
I would drain the oil and carefully cut the filter apart looking for anything unusual.
ron
Old Dec 17, 2011 | 01:20 PM
Dtownbrown's Avatar
Dtownbrown
I suppose removal of the oil pan you have to drop the cradle?
Old Dec 17, 2011 | 02:07 PM
Eric D's Avatar
Eric D
Pull plugs bar over before pulling pan. Feel and listen. Report back.
Old Dec 17, 2011 | 03:29 PM
dgrant3830's Avatar
dgrant3830
I agree...do the easy stuff first before having to go the rest of the way with it.
Old Dec 17, 2011 | 07:09 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
What does the engine builder say about the knock, willo they stand behind their work?
Old Dec 17, 2011 | 09:22 PM
Paul 75 L82's Avatar
Paul 75 L82
Get an automotive stethoscope, it will let you hear about everything.
Old Dec 18, 2011 | 11:02 PM
Dtownbrown's Avatar
Dtownbrown
Alright Guys thanks for the tips. Im thinking its a failed Lifter. NOt 100% sure though. BUt ill look more into it when I get time. Or someone could just BUY my car! lol.
Old Dec 19, 2011 | 08:06 AM
dgrant3830's Avatar
dgrant3830
A failed lifter would sound like a loud tap sound rather than a deep knock. I know, it happened to me.
Old Dec 20, 2011 | 08:55 PM
Greg_E's Avatar
Greg_E
Was the block clearanced for the stroker kit?
Read here.
http://forums.corvetteforum.com/c5-t...ng-center.html
To Cannot Figure out this Engine Noise!!!
