clutch install. What else do I need?
Old Dec 18, 2011 | 11:12 AM
20vette0107fatboy's Avatar
20vette0107fatboy
Default clutch install. What else do I need?
Im having a clutch put in this spring and was wondering what all I need to replace. My Vette is an 04 coupe. I already have the clutch. Its the Dual friction centerforce clutch. Im not changing the flywheel. Keeping stock.These are the things that I know to get. pilot bearing, remote clutch bleeder, What else..Thanks All....
Old Dec 18, 2011 | 11:17 AM
Kmcoldcars's Avatar
Kmcoldcars
While in there I would do a new pressure plate and a new slave cylinder, along with the clutch, throw out bearing, and remote bleeder.
Old Dec 18, 2011 | 11:27 AM
20vette0107fatboy
Ok Thanks. I think the pressure plate came with the clutch. I forgot about the slave cylinder. Is there one better then my oem or do I just buy a new one like I have now.
Old Dec 18, 2011 | 11:28 AM
Ultimate ride's Avatar
Ultimate ride
Replace the stiffener plate with a thicker insulated one.
Old Dec 18, 2011 | 11:34 AM
bumble-z's Avatar
bumble-z
What the heck is that?
I'd also recommend getting a new clutch master cyl.
Check for proper shimming.
Good luck.
Old Dec 18, 2011 | 11:50 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Why have you decided to keep the same flywheel? Pilot bearing should be replaced as well.
Old Dec 18, 2011 | 01:16 PM
20vette0107fatboy
Well, I was going to get the aluminum flywheel, but Ive heard good things and bad things with the centerforce clutch, as soon as I heard bad things, thats all it took. I dont want any problems when this gets all together...
To clutch install. What else do I need?
