Grounding info
Dec 18, 2011 | 08:24 PM
Oldtimer
Grounding info
What is the difference in dealing with electrical grounds on a glass bodied vehicle? Does one make mods more like house wiring??
Dec 18, 2011 | 09:26 PM
Quote:
Originally Posted by
chasboy
I do not understand the question. The C5 has no less chassis ground locations than any other vehicle.
Dec 18, 2011 | 11:28 PM
Oldtimer
lucky131969
Exactly. what if I want to mount something on a plastic panel?
Dec 18, 2011 | 11:58 PM
That's easy. Run a suitable ground wire to the chassis somewhere. Or any metal part that is grounded.
Follow the rules of current flow.
Dec 19, 2011 | 12:28 AM
Oldtimer
RonSSNova
Are the feeds to components that are entirely mounted to plastic 2 wire?
Dec 19, 2011 | 12:56 AM
chasboy
Yes, they would have to be. Plastic is non conductive to electricity.
Dec 19, 2011 | 06:50 AM
Oldtimer
RonSSNova
Of course. I wanted to confirm that so if I wanted to tap into that was far from the frame I would not have to run a separate ground wire. For example, lets say I wanted to add an LED strip to the cargo light circuit.
Dec 19, 2011 | 07:06 AM
chasboy
Again, there are chassis grounds all over the C5, you only need use the closest one to the device you are installing.
http://forums.corvetteforum.com/1548189385-post1.html
