Water Pump upgrade
Dec 19, 2011 | 04:36 PM
Water Pump upgrade
Does anyone make an upgraded water pump for the C5?
Dec 19, 2011 | 04:43 PM
St. Jude Donor '09-'10-'11
Quote:
Originally Posted by
TheVettePirate
In your opinion what factors would qualify as an "upgrade"? Are you more interested in performance or looks? Electrical or mechanical?
Yes, there are aftermarket water pumps.
Dec 19, 2011 | 04:46 PM
Eric D
I'm wanting a mechanical pump that flows better than stock.
Dec 19, 2011 | 04:48 PM
TheVettePirate
I'm curious too. What makes you think a stock water pump in not sufficient? Stock LS water pumps are used successfully in everything from street cars, to 1000 rwhp race cars, dedicated auto-x cars, etc.
Dec 19, 2011 | 05:04 PM
Dec 19, 2011 | 05:28 PM
voda1
Thanks!!!
I found what I was looking for there.
Dec 19, 2011 | 05:48 PM
St. Jude Donor '09
TheVettePirate
If you're assuming that an aftermaket pump will reduce operating temperatures, your assumption would be incorrect. The stock pump is more than adequate even for race duty. If you want lower operating temperatures consider a larger radiator and/or an EOC.
Dec 19, 2011 | 11:03 PM
Edelbrock makes one. When I was fixing my a/c I threw one on. Runs about 10 degrees cooler.
Dec 19, 2011 | 11:34 PM
SnakeaterZ28
Dec 20, 2011 | 12:47 AM
St. Jude Donor '06-'07-'08-'09
SnakeaterZ28
