PCM 442 Code?
Old Dec 20, 2011 | 01:07 AM
Choreo's Avatar
Choreo
Default PCM 442 Code?
I was idling at a red light tonight and got my first Check Engine Light. Pulled over, opened the hood and engine was still there. So I ran codes and it showed PCM - 442 H C. I cleared the code and it has not returned yet throughout 3 restarts so far.
Any idea what is getting ready to blow up?
Old Dec 20, 2011 | 01:53 AM
Lothar34's Avatar
Lothar34
http://www.obd-codes.com/p0442
Old Dec 20, 2011 | 02:20 AM
Choreo's Avatar
Choreo
Originally Posted by Lothar34
Thanks... does not "sound" too bad (as code go).
Old Dec 20, 2011 | 12:51 PM
cdkcorvette7's Avatar
cdkcorvette7
Before your try/replace anything else, pull the driver's side fuel rail cover and follow your evap line until you find a small green cap. Make sure that cap is screwed on tightly. I've seen that cap come loose over time on two different C5's and that will give you a small evap leak...
Also, make sure you tighten your gas cap until it clicks several times after filling up.
Old Dec 20, 2011 | 01:18 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Very common code---P0442 ia a "small" evap leak----99% of the time it'sjust the gas cap--either it was not put on squarely---OR it has started to leak internally---The "H" on your code means History--which means it's an old code----clear it and check the cap instalation---If it re-apears get a new cap---BUT don't get a cheapie fram or O-rielly one--get a GM cap as the aftermarkets are generally a "one size fits all" and don't seal well either---
Old Dec 20, 2011 | 10:02 PM
Choreo's Avatar
Choreo
I always replace such items with GM - even if this is my problem it lasted 11 years!
Will do.
Old Jun 28, 2012 | 09:20 AM
71blackbird's Avatar
71blackbird
New to corvettes and wanted to say thanks to the forum. Had a PCM 442 code and followed the advice above. We'll see how it goes. The small green cap is in the middle clearly marked evap port.
Old Jul 2, 2012 | 12:14 AM
JCFILM's Avatar
JCFILM
I've had that code happen twice since I purchased my car.
First time - gas cap has to be replaced.
About 3 yrs and 1600 miles later had it happen a 2nd time -
"vent solenoid" had to be replaced this time. Around $200 at my local dealer.
To PCM 442 Code?
