Starting Problem-Several Clicks Before Eventually Starting
Old Dec 20, 2011 | 09:08 PM
poppyboy's Avatar
poppyboy
Default Starting Problem-Several Clicks Before Eventually Starting
I've seen several threads similar to this issue, but never found anything that matches my issue. Only when its cold out (< 50 degrees), it often takes several starting attempts (5-8 attempts with a single click each time) before I can get my 98 6-spd Vert started. NO codes in the DIC. It's a new key and the battery is fully charged from my CTEK. I've cleaned most of the grounds in the engine area. I figure its either the 1. starter solenoid, 2. starter 3. clutch switch or 4. ignition switch. I have no lift, and really don't know how to check these items/their respective locations. Aside from bringing it somewhere, any suggestions for me to diagnose myself?
Old Dec 20, 2011 | 09:16 PM
fishmen222's Avatar
fishmen222
Check your battery connections well. Also your battery to starter solenoid connection. If you have 12.5 volts of juice and it does eventually start...sounds like a loose/coroded connection to me.
Old Dec 20, 2011 | 10:38 PM
poppyboy's Avatar
poppyboy
Thanks so much for the response. Isn't the battery-to-starter solenoid connection beneath the car?
Old Dec 21, 2011 | 06:17 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yes, it is under there. That is also the main starter, alternator and battery connection point for the whole car. Most likely you have a bad solenoid but due the obvious things first.
Old Dec 21, 2011 | 12:55 PM
poppyboy's Avatar
poppyboy
Great. Thanks!
Old Dec 21, 2011 | 08:40 PM
TZ99C5's Avatar
TZ99C5
I would definitely check the battery terminals and clean if necessary or could be lack of contact,good luck
To Starting Problem-Several Clicks Before Eventually Starting
