Re-using intake gaskets
Old Dec 21, 2011 | 11:49 PM
garrace's Avatar
garrace
Default Re-using intake gaskets
I just installed my repaired engine back in my 02 Z06. Installed the intake manifold with all new gaskets and found that I should have installed the air tube from the right exhaust before I put the the intake on. Now I can't seem to get it on without pulling the intake again. So my question is do I need to buy a new gasket set or can I re-use the ones I just put on?
Old Dec 21, 2011 | 11:54 PM
cdkcorvette7's Avatar
cdkcorvette7
I've pulled my intake a few times and just re-used the gaskets... I always look at them before reinstalling to make sure they're okay though.
Old Dec 21, 2011 | 11:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No!!
As long as theres some protrusion above the mounting surface,, your fine! I have had mine on and off the engine 3-4 times on the same manifold gaskets... All is well.
BC
To Re-using intake gaskets
