whistling alternator.
Old Dec 22, 2011 | 02:31 AM
sccs's Avatar
sccs
Default whistling alternator.
i think my alternator got pretty loud. or is it just when the engine and everything is still cold? how bad is this?
i had my hood open and in garage so it 'whistled' alot louder becouse of that. Is it maybe just the pulley at alternator?
Old Dec 22, 2011 | 07:00 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
The windings in the alternator produce noise while under load, like right after you start the car. The noise level will reduce as the battery charges. The noise pitch will change with engine speed. This is normal.
For what it’s worth, there are 36 polls and if the engine is idling at 625 rpm and the alternator rotates at about 3 to 1 with stock pulley, the resulting frequency is, 36*625*3/60 = ~1125Hz, the whine noise you hear.
If you unplug the plug on the alternator the noise should go away. If not, it could be the bearings.
Last edited by Eric D; Dec 22, 2011 at 07:16 AM. Reason: Updated after seeing Zap City's Post about bearing.
Old Dec 22, 2011 | 07:05 AM
Zap City's Avatar
Zap City
St. Jude Donor '13
I just replaced mine for the same issue after going completely through the belts and pulleys. It quieted right down. BTW, the car has 24K miles. It was driving me crazy. Bad bearings seemed to be the culprit and it was getting worse.
Old Dec 22, 2011 | 07:18 AM
Eric D's Avatar
Eric D
Good point, it could very well be a bad bearing. By unplugging the alternator if bearings the noise will not change. If the noise quits when unplugged this is normal 36th order whine.
Old Dec 22, 2011 | 07:23 AM
sccs's Avatar
sccs
thanks for that explanation! with the bearings you mean in the alternator? and if these bearings are bad can only the berings be changed without whole alternator?
Old Dec 22, 2011 | 07:27 AM
Eric D's Avatar
Eric D
Yes, the alternator bearings, and yes, if you can find replacements they can be changed out. Years back this was a pretty normal thing to do along with the rotor brushes. They are hard to find now days.
To whistling alternator.
