Computer question
Old May 9, 2002 | 05:20 PM
Jerryk's Avatar
Jerryk
Default Computer question
once you have the stock computer programed and you like to make changes can you than hook up a unit like the hypertech and make more changes and if you go back to stock would it be stock stock or the programed stock :crazy:
Old May 9, 2002 | 05:52 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: Computer question (Jerryk)
The HPP3 will download whatever code you currently have in your PCM. It does not have a stock flash of it's own.
If you had custom programming, then installed the HPP3 tuning, and later reverted to "stock" tuning you would be back to your custom tuning (not the original stock flash which was lost with your first custom programming.)
[Modified by ToplessTexan, 3:53 PM 5/9/2002]
