C6 Z06 Brake Conversion
Old Dec 22, 2011 | 03:23 PM
jcsperson's Avatar
jcsperson
NC Events Coordinator
Default C6 Z06 Brake Conversion
Has anyone done this swap?
97-04 C5 CORVETTE C6 Z06 BRAKE CONVERSION UPGRADE KIT
Are any other parts required?
Plusses? Minuses? Wheel fitment problems?
Apologies in advance if this is a repeat topic.
Old Dec 22, 2011 | 07:07 PM
TriplBlk's Avatar
TriplBlk
Stick to venders here man, $2400 is wayyyyyyy overpriced. They sell on here for under 2k
Oh and you need wheels to fit the brakes, at least 18" up front
Old Dec 22, 2011 | 07:21 PM
jcsperson's Avatar
jcsperson
I've got 19" CCWs all around.
Old Dec 22, 2011 | 07:26 PM
TriplBlk's Avatar
TriplBlk
Ok did you buy those wheels new? You should call CCW and give them the specs of your wheels and double check that you they can fit. Do this before you drop that 2k
Old Dec 22, 2011 | 09:14 PM
SR-71's Avatar
SR-71
I have 18/19 CCW SP500's made for a BBK and the caliper to spoke clearance is verrrrry tight with my C6Z setup. What model CCW's do you have?
Old Dec 22, 2011 | 10:17 PM
jcsperson's Avatar
jcsperson
I just bought the car a month ago and they came with the CCWs. All I know is they're SP500 19x10f and 19x11r according to the original invoice from the previous owner, but that's all it has on it. I guess I'll have to contact CCW and see if they have a record of the specs for that set of wheels.
Old Dec 22, 2011 | 10:23 PM
TriplBlk's Avatar
TriplBlk
Yup do that, just to make sure man. You wouldnt wanna drop 2k and find out the dont fit ya know?
Old Dec 23, 2011 | 10:02 AM
SR-71's Avatar
SR-71
If your wheels have the bigger lips 2" front and 3" rear, the calipers will never clear. The BBK wheels have smaller 1" front and 2" rear lips.
Old Dec 23, 2011 | 10:14 AM
jcsperson's Avatar
jcsperson
Just measured 'em, 2" front and 3" rear. Dang.
Old Dec 23, 2011 | 12:48 PM
NealB's Avatar
NealB
As was suggested, call CCW and get the straight answer
I called CCW to order 18 x 10 front and 18 x 11 rear and they told me that if I wanted BBK in the future, that 9.5 and 10.5 were the biggest that could be made to fit
So I doubt yours will clear but call them
I do have the front C6 Z06 template you could test fit to your CCWs, so PM me an addy and I'll send it if you want
If you do get C6 Z06 brakes, think about:
whether padlets (6 per front wheel) or one piece pads (two per front wheel) -- limited vendors for the one piece but better IMHO
whether get aftermarket pad retention bolts -- some people have had the bolts sieze in the caliper and break off At least one vendor makes a replacement bolt with elevated traditional head for normal wrench
whether to get two piece rotor in front to save weight -- something like 6# per side (or 9# I forget)
I wound up buying TSW Interlagos wheels to fit, and got a WilWood BBK for the same money as the C6 Z06 with two piece rotors and one piece pads
so look around if you want BBK, most companies have templates on their web site you can fit to your wheels
Old Dec 23, 2011 | 01:02 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Dont suppose you have a pic of your wheels?
I've heard that the offsets are different to clear so the spokes aren't as arched as the normal sets made for regular brakes.
Old Dec 23, 2011 | 01:05 PM
tiojames's Avatar
tiojames
If you find they will fit, I would give Gene Cully a call at GM parts house(forum vender).
Old Dec 23, 2011 | 03:36 PM
SR-71's Avatar
SR-71
http://forums.corvetteforum.com/c5-g...-silver-2.html
Couple pics of my car in this thread.
If you need some up close pics of the wheels just let me know I'll take a couple for you.
Old Dec 23, 2011 | 04:42 PM
backnblack2003z06's Avatar
backnblack2003z06
C6 z51 brakes will bolt right up. I have them on my car with my SP500's in 18/19. All you need are the rotors and caliper brackets. There was a vendor that had a kit for right around $500 for all 4 corners. If you want bigger brakes to fill up the wheels I'd go that route and save the extra $1500 for go fast mods.
Old Dec 28, 2011 | 11:56 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Looks good.
To C6 Z06 Brake Conversion
