endlinks
Old Dec 23, 2011 | 10:38 PM
wagner262's Avatar
wagner262
Default endlinks
endlinks are shot because Gm decided to hold the suspension together with a sweet plastic piece.
anyways I have a 99 pretty sure the sway is stock. can i use an 02 z06 metal endlinks for my 1999 FRC?
Old Dec 23, 2011 | 10:47 PM
jd86L98's Avatar
jd86L98
yes
Old Dec 23, 2011 | 10:59 PM
Navybluevette's Avatar
Navybluevette
St. Jude Donor '12-'13-'14-'15-'16-'17
Originally Posted by jd86L98
yes
Exact replacement.
Old Dec 24, 2011 | 12:50 AM
SG Lou's Avatar
SG Lou
If you're going to purchase new why don't you get the updated 2011 versions. Instead of having to use an Allen key to hold the shaft the newer ones have a 10mm hex end....makes it easier to install
GM # 20822934
Old Dec 24, 2011 | 08:23 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Don't know if he has anymore but if he does... You can get 4 BRAND NEW metal end links (with the 10mm hex head) and the nuts for $80.00 delivered from forum member:
piper1929
GM #25932329 w/ male hex - (1) set of (4) links
GM #11516078 M12x1.75 - (8) locking nut/washer
Just installed them on my car.
Old Dec 24, 2011 | 10:11 PM
m6 c5's Avatar
m6 c5
GM # 20822934
You dont need an allen wrench to remove the old ones, all you need is either an open end or an adjustable wrench to keep it from rotating.
To endlinks
