What upgrade should I do next?
Dec 24, 2011 | 10:20 AM
I'm not looking for bling, my dad has that covered on his Corvette.
I've added
-228/232 Cam
-Long tube headers
-High flow cats
-X-Pipe
-B&B Bullets
-Hurricane air intake
-LS7 clutch
-Double valve springs
-Titanium retainers
-10 degree locks & seals
-New plugs and Taylor plug wires
-Ported throttle body
-Tuned
400 whp 360 ft-lbs torque
It's a 2002 base model
What would be the next logical step?
Forged internals, diff brace, wider tires?
Dec 24, 2011 | 10:47 AM
Dec 24, 2011 | 11:21 AM
Quote:
Originally Posted by
paint it black vette
gears
3.90 or 4.10
Dec 24, 2011 | 12:02 PM
Fuzzy dice, definitely.
And one of these:
Dec 24, 2011 | 12:20 PM
Dec 24, 2011 | 12:28 PM
a better tuner.
New dyno tune, your not getting enough out of what you have.
next mod ?
1: pp 243 heads or AFR 210 heads or TF 215 heads
2: good light weight wheels and sticky tires.
Dec 24, 2011 | 03:04 PM
Heads or diff brace
Unless you are at the track on sticky tires I would not do gears
Dec 24, 2011 | 04:34 PM
I disagee about the tuner - it's exactly where it should be with LS1 heads.
AU N EGL
a better tuner.
Dec 24, 2011 | 04:46 PM
K9Leader
And one of these:
Dec 24, 2011 | 05:09 PM
NC Events Coordinator
Levi Walker
It goes faster now so it needs to stop better.
Better brakes.
Dec 24, 2011 | 07:59 PM
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
4.10 gears for the MN6 gear match up!
Dec 24, 2011 | 08:13 PM
FAST LSX™ 92mm Manifold with LS2 90mm TB
AFR 205 heads .61cc
Dec 24, 2011 | 08:17 PM
even stock 243s and a retune would work well.
Dec 25, 2011 | 09:42 AM
Fuzzy dice will be my next mod! LOL
gears, brakes, and heads (not in any specific order)
With new gears, how much would I loose on my top end?
Thanks for the suggestions
Dec 25, 2011 | 10:25 AM
Dec 25, 2011 | 10:42 AM
3:90 diff, would really amplify the other mods. That 400hp would feel as though you had closer to 500
Dec 25, 2011 | 12:03 PM
Dec 25, 2011 | 12:26 PM
tlove32
then he needs he 243 heads or other aftermarket heads
Dec 25, 2011 | 12:36 PM
AU N EGL
What type of gains would I see with new heads?
Dec 25, 2011 | 12:41 PM
Levi Walker
40 to 60 depending on the heads with your other set ups
