Lug nut removal on HRE wheels?
Old Dec 26, 2011 | 10:55 PM
95wht6spd's Avatar
95wht6spd
Default Lug nut removal on HRE wheels?
Having trouble getting a socket that fits. Tried several sizes including a 19mm deep well socket, but nothing fits that I have. Doesn't even start to grip. I cannot tell for sure, but I think socket is hitting wall of the wheel opening, as there is very little space around lug nut. Any advice?
Old Dec 27, 2011 | 12:43 AM
lantzpantz's Avatar
lantzpantz
thin walled 19mm chrome socket?
or look online for thin walled wheel socket ?
http://www.tirerack.com/accessories/detail.jsp?ID=1
Old Dec 27, 2011 | 01:43 PM
95wht6spd's Avatar
95wht6spd
Yeah I figured it was not fitting due to space, just wanted others opinion. Harbor Freight has a 4 Piece 1/2" Drive Lug Nut Socket Set that I may try. It doesn't say thin wall, but since it is made for lug nuts figure it probably is. Can get it locally and return if it doesn't fit. A lot of the "thin wall" on line don't look any thiner than what I have. I wish I had something larger than a 19mm to just test it.
Old Dec 27, 2011 | 01:49 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
I use a chrome 3/8 drive socket with a 1/2" adapter for wheels requiring a thin socket. I would stay away from using a cheap socket. If the socket were to break there is a good chance you are going to damage your rim.
Old Dec 27, 2011 | 08:57 PM
AngryTurtle's Avatar
AngryTurtle
Id suggest something like this.
http://www.sears.com/shc/s/p_10153_1...u=SPM198326581
Old Dec 27, 2011 | 11:57 PM
lantzpantz's Avatar
lantzpantz
this is actually a good idea if you have a 3/8 19mm around
Old Dec 28, 2011 | 08:56 PM
95wht6spd's Avatar
95wht6spd
Figured out the problem, the nuts are 13/16. Used one of my standard sockets and worked fine. thx
To Lug nut removal on HRE wheels?
