Window Motor Replacement
Old Dec 27, 2011 | 05:50 PM
TomsZ06's Avatar
TomsZ06
Default Window Motor Replacement
I am off this week and decided to tackle replacing my passenger window motor which has gone south. I do have voltage going to it but it still will not go down. I even tried the tap on the motor trick but it did not work. I did get the door panel off along with removing my speakers. I ordered a replacement from Napa and I will be picking it up tomorrow morning. Here is my question. How do I remove the regulator cables that goes into the plastic housing holding the motor? They appear to be spring loaded. I was not successful in finding a good write up on how this is done. Any help would be very appreciated. I also accomplished the rocking seat fix today. It was not as bad as I thought it was going to be. Everything went pretty much as to the write I did find on the forum. After that fix I went down to Napa to order the window motor and I could not believe how much better the seat felt with no rocking movement.
Old Dec 27, 2011 | 06:09 PM
k0ts's Avatar
k0ts
The new regulator will include all cables and is assembled...
Old Dec 27, 2011 | 07:01 PM
TomsZ06's Avatar
TomsZ06
I did not order the regulator, just the motor assembly that has the plastic housing that the cables somhow mount to it.
Old Dec 27, 2011 | 07:11 PM
k0ts's Avatar
k0ts
http://forums.corvetteforum.com/c5-t...uild-pics.html
Old Dec 27, 2011 | 08:35 PM
TomsZ06's Avatar
TomsZ06
Thanks. That is what I needed.
To Window Motor Replacement
