Suspension issue
Old Dec 27, 2011 | 06:01 PM
tac4005's Avatar
tac4005
Default Suspension issue
I had my LR wheel recently repaired. The tech simply jacked up that side of my "03 from the rear. Ever since then it rides like a sled. Every small bump in the road feels huge. I always drive on "tour" mode. I know the suspension is supposed to be tight but this is too much. Is there a reset button or switch? HELP!
Terry
Old Dec 27, 2011 | 06:17 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
This might be an easy one...check your tire pressure. The tech may have put too much air in the repaired tire/wheel. I'm not aware of any suspension 'reset'.
Old Dec 27, 2011 | 10:58 PM
tac4005's Avatar
tac4005
Turns out you may be right as the air pressure was 65 psi! I'll pay more attention next time I drive. Thanks!
Old Dec 27, 2011 | 11:01 PM
Gray Ghost GS
To Suspension issue
