Crank turned without timing chain, issue?
Old Dec 29, 2011 | 11:14 PM
lucky131969's Avatar
lucky131969
Originally Posted by Eric D
Lucky, I'm not following what you are saying. The crank doesn't care about compression or exhaust. 360° puts the crank in the same position. The cam does care and takes 720° with the chain connect of crankshaft to put the cam back to its 360° position. As long as the cam sprocket dot is facing down and the crank sprocket dot is facing up, connect the chain the engine is timed correctly. Even if someone put the cam sprocket dot facing up with the crankshaft sprocket up the timing will still be correct.
You are absolutely right. I did not finish that thought..was on the way out the door. Glad you stepped in to clarify.
Old Dec 30, 2011 | 09:21 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Just saw this thread... my thoughts?
Your lack of starting has nothing to do with the cam being spun while not connected to the crank. I just got done with a cam swap on the engine in my avatar and I can tell you the crank was spun several times to get at each piston top for cleaning. Now, when you reassemble, the cam is key'd (by way of the dowel pin) to the cam gear and the crank's gear has it's own dot. If they are lined up like in previous posts you are good to go.
So with that being said, you tore the engine down again for no reason except now you can clean the pistons/heads.
Your issue of not firing can be anything from fuel and spark, but it's not valve timing/air.
When you get it all back together you'll be back to where you started. Make sure you hook up all grounds... You will be at square one checking that you have fuel pressure, and then checking that you're getting spark. One of those two elements are your problem.
Old Dec 30, 2011 | 09:29 AM
Kmcoldcars's Avatar
Kmcoldcars
Originally Posted by Sidewinderx7
After further clean up and investigation it looks like the valves are bent. They do have a common scuff on all the valves and 3 of 4 are not seating ... with a gap big enough to see through in one of them.
So, it looks like the answer to the original question: Was the timing effected when the crank/cam moved
was yes, the timing was off enough to damage the valves.
Oddly enough, I turned the motor by hand before using the starter and it had no out of ordinary resistance and when I used the starter I couldn't hear any piston/valve slap.
Thanks guys! I'll keep it updated...
From Joshua
[QUOTE]Your lack of starting has nothing to do with the cam being spun while not connected to the crank.
So with that being said, you tore the engine down again for no reason except now you can clean the pistons.[QUOTE]
The above quote from Sidewinderx7 indicates the valves are bent. I think he did have reason to pull the engine apart.
Old Dec 30, 2011 | 10:06 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
[QUOTE=Kmcoldcars;1579600653]From Joshua
Hmmm, missed the post about valves.
Ouch.
Old Dec 30, 2011 | 12:03 PM
Sidewinderx7's Avatar
Sidewinderx7
lol, yeah they bent... plus it did need a good cleaning.
I wouldn't think it would effect the timing since they both moved, and I continued moving them until the dots were aligned again, but apparently something went wrong because the valves did hit the pistons.
Old Dec 30, 2011 | 02:31 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
This is obviously a lesson for everyone that as someone else mentioned already, always loosen the rocker arms first, before rotating anything on the cam or crank assemblies. I'm thinking that most assume there wouldn't be any contact but on these engines, there isn't enough clearance.
Old Dec 31, 2011 | 10:10 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
CLIFF NOTES: don't use starter to rotate crank
OP'er, what pistons are in the block?
Old Dec 31, 2011 | 10:36 AM
SMaster's Avatar
SMaster
Even if someone put the cam sprocket dot facing up with the crankshaft sprocket up the timing will still be correct. In all cases the crank sprocket ALWAYS has be facing up.
A little off topic but that explains why I had to tell so many guys over the years to rotate the distributor 180°. Dot to Dot on the older SBC was actually putting the camshaft in the position to fire #6 but they would put the distributor pointing to #1 thinking dot to dot in aligning #1 cylinder.
Your point is, and correctly so, as long as it Dot to Dot, or 12 and 12 O'Clock it doesn't matter.
