"LOW COOLANT" message wont go away!!
Old Dec 29, 2011 | 05:29 PM
Arttysvette's Avatar
Arttysvette
Default "LOW COOLANT" message wont go away!!
Hello everyone!
I have this issue with the "LOW COOLANT" message that just wont go a way!! I had to replace my radiator on my 98 vette due to a small leak/crack on the radiator. Everything went well, but the message keep coming up and I just can't clear it.
Does anyone know how to clear this message?
Thank you in advance
Old Dec 29, 2011 | 05:31 PM
lucky131969's Avatar
lucky131969
Originally Posted by Arttysvette
Hello everyone!
Is the connector plugged into the sensor?
Old Dec 29, 2011 | 05:42 PM
Arttysvette
Do you mean the sensor underneath the coolant reservoir? if so, the answer is YES.
Old Dec 29, 2011 | 06:01 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Hello everyone!
Tap on the coolant tank where the sensor is located. Sometimes when the coolant has been drained and filled on the tank, air bubble sometimes sit just where the sensor is and give you the false reading.
__________________
Old Dec 29, 2011 | 06:05 PM
IM28702's Avatar
IM28702
I once accidentally installed the float sensor upside down, and it constantly read low. Check to be sure it's in right.
Arttysvette
Rick, I am afraid I have done that I believe I took all the air bubbles out of the system. does this mean I need a new sensor?
lucky131969
You can easily test the circuit with a jumper wire. If the message goes away with the connector jumpered, you have a sensor issue, bubble, dirty, etc.
Old Dec 29, 2011 | 06:08 PM
Arttysvette
Thanks!! I will try the jumper test tonight when I get home
I will keep you guys post it on the out come.
Old Dec 29, 2011 | 06:11 PM
Supporting Vendor
Old Dec 30, 2011 | 02:19 PM
Arttysvette
Well, It appears that i have a bad sensor. I tested the system with the jumper and the message disappeared Now, I have been searching for a replacement sensor on the web, and nothing comes back
I supposed I could go to the local autoparts store and see if they have them. what do you guys suggest?
Thank you.
Old Dec 30, 2011 | 02:28 PM
IM28702's Avatar
IM28702
You sure it's in right-side-up?
Old Dec 30, 2011 | 02:31 PM
Paul Wood's Avatar
Paul Wood
Thank you.
Contact Gene @GMPartsHouse Look to the far left along the side of the main page and you will find his ad. He has a great reputation and is a forum vendor. Good Luck.
Old Dec 30, 2011 | 02:33 PM
Arttysvette
Yes! the sensor is in it's original position. I never removed it from the reservoir tank, I only removed the radiator. I heard the if you clean the sensor would work once again..... done that too!!
Old Dec 30, 2011 | 02:34 PM
Arttysvette
Thanks!! I will look right now
Old Dec 30, 2011 | 03:14 PM
IM28702's Avatar
IM28702
Rats. I hate buying new parts instead of fixing the old one. At least you gave it the effort...
Old Dec 30, 2011 | 04:00 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
There are online vendors here, but shipping will probably make it more expensive than just getting if from a local dealership. Call around, some are better than others when it comes to prices.
Old Dec 30, 2011 | 05:14 PM
Supporting Vendor
Just a question before buying a new sensor. How hard did you hit the tank/sensor? You have to hit it with pretty good force to have the bubbles come out.
Old Dec 30, 2011 | 07:08 PM
lucky131969
....OP has a 98, so that tank is almost 14 years old. I would not be beating on it too much.....
To "LOW COOLANT" message wont go away!!
